Could someone give me (somewhat detailed) directions on how to switch out a WMV file's audio track for another without recompressing the file?
I can make the new audio track exactly the same length beforehand. I tried using ASFbin but that just said "general compatbility error" when I tried to add the new WMA file I'd made for the purpose.
I've heard Expression Encoder bandied around - what exactly would I do within that program to achieve this result?
Well, AsfBin is not bug-free (sadly). When it fails, I give a try to SolveigMM ASF Multiplexer or ffmpeg.
As for Expression Encoder... well, JMO, I think it's overkill to use a heavy-weight bloatware just for remuxing one file
(assuming that it can remux ASF files, I have never used it, so I don't know). -
Note this website hotlinks to WME . But you want to use Windows Media Stream Editor specifically, which comes with WME , not WME which is for encoding
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
Recompressing MKV audio
By Jorpho in forum Video ConversionReplies: 17Last Post: 24th Feb 2009, 09:02 -
Help transcoding just audio track in WMV file (wmap -> wma2)
By plan-b in forum AudioReplies: 0Last Post: 6th Nov 2008, 20:59 -
Recompressing Audio Stream
By jdvideo in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2008, 19:04 -
Audio Stream Swap in WMV video files
By a1s2d3f4 in forum Newbie / General discussionsReplies: 17Last Post: 15th Sep 2008, 11:57
