Dear receiver,
I am trying to convert clips that are m2v1 files into PC friendly files and I cannot loose any quality of the originals that is 1920X1020.
During the last few days I have downloaded this and that and what not and the latest efford was to download a programme called "Any video converter". I just cannot find out how to make files that are't lossy with that either. I'd have to be able to play them afterwards with other programmes and my editing software as well.. Maybe even Any Video converter is wrong for that purpose?
I would appreciate it very much if someone was able to help!![]()
With thankful greetings,
Johanna
And if you want to keep them as MPEG2-encoded video files in an MPEG2 container, just mux (multiplex) them with Imago (though it will probably want an audio stream to go with it - use mp2 or ac3).
However you remux, you will not lose ANY quality.
BTW, where did you get the "m2v1" label from? On a PC, most elementary MPEG2 video streams are just labeled: *.m2v (notice the lack of the "1").
Convert audio without loosing video quality.
By mglon in forum Video ConversionReplies: 6Last Post: 23rd Aug 2012, 14:55 -
remove a logo without loosing quality
By mathmax in forum DVD RippingReplies: 13Last Post: 9th Jul 2010, 12:54 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Vegas 9, and HD hero. Loosing too much quality rendering, need help.
By carl1864 in forum EditingReplies: 3Last Post: 26th Mar 2010, 16:54 -
How to get AVCHD on Harddrive of PS3 without loosing quality
By alex1357 in forum Video ConversionReplies: 2Last Post: 7th Jun 2008, 11:06
