I'm trying to join 2 mp4's and the result should be the combined time of both files which should be 4:30 (ms), but Yamb's join is giving me 6:46. The video plays fine but when it reaches 4:30 the scrub bar which still shows about 1/3 left to play, jumps to the end of the scrub bar. I wouldn't mind this for my own work, but it is for a client and I cannot give them a file that has an incorrect timecode. Anyone know what I can do to fix this?
I encoded two PICVideo AVIs out of premier of my 3D animation because they had to be less than 2GB, then used handbrake to make the m4v's, then yamb to rewrite the m4v to mp4. This works for everything but joining...have tried other joiner freeware's with no luck.
Also a piece of advice - you might not need to join them at all. Its been my experience a lot of video players will automatically play the following video file in sequence. So simply name your two files sequentially and you should be able to nearly seamlessly play them together.
However if seamless playback is needed then you should try something else like winff or avidemux and use the copy modes.
Also handbrake can output .mp4 files. Choose mp4 as the container in the output section. I would make sure you call the file filename.mp4 just to be 100% sure you get a mp4 file from handbrake.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Video to Video Converter has a video joiner in its 'Tool' section. That might work.
Using YAMB to demux audio from MP4 problem...
By takearushfan in forum AudioReplies: 2Last Post: 2nd Feb 2012, 01:44 -
MKV to MP4 Hell (MKVExtractGUI and YAMB)
By Axmann8 in forum Video ConversionReplies: 2Last Post: 6th Dec 2011, 06:50 -
Yamb AVI to MP4 (with AAC audio)
By djalman in forum Video ConversionReplies: 5Last Post: 20th Aug 2011, 18:32 -
Problems splitting MP4 with Yamb
By trokua in forum Video ConversionReplies: 0Last Post: 3rd Aug 2010, 23:10 -
Avidemux + YAMB couldn't join my .mp4 files - help!
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 14th Jan 2010, 16:33
s), but
