Hi there!
Just wondering if the only difference between the 343 and 444 is the progressive scan and the Mp3 support? I know the 444 supports both PAL and NTSC, does the 343 also do that?
If the prog and Mp3 is the only diff, and the picture quality is equal, i'll probably settle with the 343. Any ideas?
//With Kind Regards,Torbjorn Stavas
My DV-343 does appear to support both NTSC and PAL, that is on SVCD and VCD... obviously with DVD it runs into other issues...
I burned and played a PAL size and framerate VCD, it played nicely (even though the TV is NTSC)... -
there is difference in output available.
in europe scart connection 444 has RGB output. it also has optical output. -
Also, in Europe it seems that the 444 does NOT have progressive scan. So it comes down to RGB and mp3 and digital audio out - assuming the 343 doesn't have that - and the skinny look. But then, that was enough for me!
Trek alert - PBS Pioneers of Television series on Star Trek and Twi Zone
By edDV in forum Off topicReplies: 18Last Post: 2nd Feb 2011, 07:36 -
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2010, 00:48 -
Replacing a HDD on the Sony RDR-HX780 or Pioneers WITHOUT a service remote!
By highvolumeJP in forum DVD & Blu-ray RecordersReplies: 5Last Post: 9th Dec 2008, 12:56 -
YUV 444 Conversion
By Dave1024 in forum ProgrammingReplies: 1Last Post: 24th Jun 2008, 08:31 -
ac3/mpeg same on PC, diff. on TV
By spiritgumm in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2008, 08:39
