    Jun 2011
    Moon
    Why do the Generated Media animations "loop" in Sony Vegas?
    I simply want my text to eg, slide in from the right and then stay there?
    If I cut at the point the motion stops and add a second static clip it NEVER lines up perfectly with the animated text (unless you have 2 hours to make it!!!).
    If I time stretch the clip then the text comes in too slowly!
    Any ideas that dont take an eternity to complete?
    Thanks!!
    Mar 2004
    Texas, USA
    Make certain that the length of the clip in "Edit Generated Media" is exactly the same as the length of the clip on your time-line. At least in VMS 11 having the time-line clip longer than what you told the generated media properties will cause it to loop. If your time-line clip is too short, it won't complete the action.
    Jun 2011
    Moon
    Ah Ha! So where do I find the preference setting to tell the "generated media" how long to be when I create it?
    Mar 2004
    Texas, USA
    I'm not at my editing system at the moment, but IIRC, at the top of the window where you set properties (text/font/color/etc) for the text event there's a time box that shows hrs : minutes : seconds ; frames. I think mine defaults to 5 seconds. You can change the time after you've got it in the time-line (right-click -> edit generated media), so it doesn't have to be right to start. I ran into this the first time I tried to do a credit roll.
    Oct 2011
    Finland
    This may be an old technique, but one way to do it is to create a selection area on the timeline for the size you want, right-click the track in that selection area, insert the generated media.
    Note that in Titles&Text, you can change the length of the event, which will change the duration of the animation. However, that also changes the duration of the text itself. No modifications are possible to the animation sequences themselves.
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Use Keyframes.
    Most every property can be keyframed.
    Keyframing is the most commonly used tool in animation.
    Keyframes define the behaviors and appearances over time.
    Jun 2011
    Moon
    This is also interesting!
    Seems to work too?
    :Found in another of my posts!
