  1. I have just downloaded the latest VCD Easy from your site and also the aspi drivers. Tried to use the settings but cannot access the pulldown menu on the cd writer to select my cd writer. What can I do?
  2. Check out the text file called "VCDEasy FAQ.TXT" that is installed with the program. It contains a lot of information about ASPI problems. That is most likely the cause here. When you open the program, does it say ASPI is OK?
    If ASPI is OK, make sure "CDRAO Integration" is enabled (Settings / VCDEasy).
