Does anyone else get this error with the line darkener Hysteria? Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Results 1 to 16 of 16
I just tried it and it worked fine. Make sure you have the right versions of the filters it uses. Ie, MaskTools 2.0.
And if you still have problems, maybe you do have a memory issue, try some memory integrity checking software e.g. memtest86+ etc..
'this error' ? Which error?Does anyone else get this error with the line darkener Hysteria?
Personally I use Hysteria with
Avisynth MT 2.6 from: http://forum.doom9.org/showthread.php?t=148782
and
MaskTools from: http://tmod.nmm-hd.org/Misc/mt_masktools-26-for-2.6alpha4.7z
without a problem.
Cu Selur -
doesn't matter, it will still work regardless of # cores
If you ran the memory tests, and they passed, you can also try cleaning out the plugins folder. Empty it out and only put in the ones you need. Go 1 by 1 replacing them back
Also post your full script - are you sure it's the hysteria call (not some other filter or combination) ?
Also make sure you're using the correct mt_masktools: (don't use both)
Use mt_masktools-25.dll for avisynth 2.5.x
Use mt_masktools-26.dll for avisynth 2.6.x -
I honestly dont understand why it doesnt work. I can preview it fine in media player classic, but in megui the x.264 crashes. I did manage to get past that error message about reading and writing the protected memory by disabling dep. (it kept blocking the hysteria in the programs I ran it in)
avisynth subtitle script problem
By dj-big in forum SubtitleReplies: 0Last Post: 20th Dec 2012, 01:49 -
AviSynth / Gordian Knot problem
By walruss in forum Video ConversionReplies: 6Last Post: 12th Sep 2012, 04:55 -
PIP Problem using AviSynth
By wakeup in forum EditingReplies: 4Last Post: 20th Feb 2012, 19:14 -
W7 + AviSynth + VC-1 = problem?
By follz20 in forum Video ConversionReplies: 5Last Post: 5th May 2010, 13:16 -
AviSynth Script Problem
By Eva-Unit01 in forum EditingReplies: 21Last Post: 29th Dec 2009, 13:00
