I acquired commercial copies of operas on DVD that are over-compressed and video and audio quality is poor. How can I decompress a DVD of say 2.19GB (probably more than 50% compression), to a more acceptable 4GB and 70%+ compression? When using DVDShrink myself, I either re-author a recording of 140+ minutes, or burn to a dual layer disc.
All you're going to do is replace blocky artifacts with smooth, greasy looking gradients. You won't get any detail back. It will require decomrpessing, running a deblocking filter, then recompressing the video at a higher bitrate.
you'd have to buy the original master video source from before it was encoded to poor quality dvd to make it any better. you can't magically make up better quality from nothing.
Weird audio decompression problems in Virtualdub
By Bully9 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2012, 06:21 -
VirtualDub: Working with MKV & MP4 (frame jumps, RGB decompression etc.)
By pokepika in forum Video ConversionReplies: 4Last Post: 21st Sep 2011, 19:28 -
the decompression codec cannot decompress to an rgb format
By flemmo in forum Video ConversionReplies: 11Last Post: 19th Jul 2009, 09:23 -
DVP5990-37.. poor avi decompression playback quality?
By Gareee in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Jan 2009, 13:34
