Results 1 to 13 of 13
  1. I keep trying and I constantly get errors.
    Is there a specific program that has to be installed for it to work?
  2. I know how to use the program. I just constantly get errors when I do.
  3. Because it can't encode true hd
  4. If it cannot, then why is that one of the options?
  5. It can decode truehd , not encode
  6. Originally Posted by poisondeathray View Post
    And, again I ask, if it cannot encode to it, why is that listed as an encoding option?
  7. It's meant for demuxing. The GUI doesn't neceesarily reflect what eac3to.exe can or cannot do.
    You cannot encode DTS-MA or TrueHD with eac3to
    Notice TrueHD isn't listed
    http://en.wikibooks.org/wiki/Eac3to/How_to_Use#Audio_Encoders
  8. Originally Posted by poisondeathray View Post
    Then it shouldn't even be listed as an option to "save to." That's just stupid. Thanks...
    Are there any programs that DO encode?
  9. Originally Posted by digitalfreaknyc View Post
    No free ones for TrueHD, you need one of the Dolby Suite encoders
  10. Originally Posted by poisondeathray View Post
    Gotcha. What about DTS-HD MA?
  11. Originally Posted by digitalfreaknyc View Post
    Same, no free options . You need DTS Master Audio Suite
  12. Crap. Thank you very much for your help
