I've bought a Vivanco UR 12 in the hope that I can use it to hack my Panasonic DMP BD45 for all regions.
Having had a look around, I see the key codes here are for other URCs.
I'd be grateful for any help on this!
Many thanks in advance.
even if there is a hack for your player it would only be for the dvd side of the player. there are a very few blueray players
that can even be hacked. -
I've programmed the Vivanco UR with the correct key codes but running through them from 1-0 doesn't affect the DVD player...
Thanks again for the information. I'm only interested in this make and model, though. Do you happen to know anything about it?
Have you contacted Panasonic? I know that, in this country at least, Panasonic dealers will make DVD players zone-free at no charge if you take them in. They won't, however, de-zone Blu-ray playback.
That's not something I'd considered but I can give it a try - I'll ask the vendor if it's an option. Doesn't matter about the Blu-ray; just the DVD side is what I'm interested in, though the machine does play both. Thanks very much for the tip!
Panasonic DMP-BDT1100
By Nighthawke in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th May 2012, 17:30 -
Register DivX for Panasonic BD45?
By Falxifer in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Dec 2010, 17:09 -
Panasonic DMP-BD85K
By crowheart in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Nov 2010, 22:59 -
Panasonic DMP-BD45 & 65 & DivxHD?
By inoueto in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Aug 2010, 18:46 -
Panasonic DMP BD 60
By wrinaldo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Apr 2010, 07:47
