Some old videos I would like to check on, are in RealPlayer .RM format. 99,99% of them play fine, all one need is to install just the RealAlternative (w/o the browser support it is pretty slim package) and things work just fine, even on Windows 2000 SP4 and old BSplayer 1.41So far, so good. However I get plenty of vids that are .RM by extension, however inside the header look quite different AND they refuse to play in anything I tried yet.
So after some time battling with this alone I decided to go and ask, if there is any conversion tool, that strip the weird header and make these play as normal .RM files, or do I need to re-encode them (I fear loss of quality) to be able actually play them back?
The header look this way:
Normal, playable header or .RM file looks like this:Code:.RMF PROP 2 B@ B@ x x f *04ň ˜ MDPR ă l l > * r-video/x-pn-multirate-realvideo logical stream&logical-video/x-pn-multirate-realvideo b b ˜ € Ńł ~Ĺ eWD ˜ ˆ ASMRuleBook p#($Bandwidth < 10000),TimestampDelivery=T,DropByN=T,priority=9;#($Bandwidth >= 10000) && ($Bandwidth < 12000),AverageBandwidth=10000,Priority=9;#($Bandwidth >= 10000) && ($Bandwidth < 12000),AverageBandwidth=0,Priority=5,OnDepend="1";#($Bandwidth >= 12000) && ($Bandwidth < 26000),AverageBandwidth=12000,Priority=9;#($Bandwidth >= 12000) && ($Bandwidth < 26000),AverageBandwidth=0,Priority=5,OnDepend="3";#($Bandwidth >= 26000) && ($Bandwidth < 180900),AverageBandwidth=26000,Priority=9;#($Bandwidth >= 26000) && ($Bandwidth < 180900),AverageBandwidth=0,Priority=5,OnDepend="5";#($Bandwidth >= 180900) && ($Bandwidth < 903532),AverageBandwidth=180900,Priority=9;#($Bandwidth >= 180900) && ($Bandwidth < 903532),AverageBandwidth=0,Priority=5,OnDepend="7";#($Bandwidth >= 903532),AverageBandwidth=903532,Priority=9;#($Bandwidth >= 903532),AverageBandwidth=0,Priority=5,OnDepend="9"; $ SeekGreaterOnSwitch 3 RMFF 1.0 Flags % MinimumSwitchOverlap EndTime rMDPR Ű x x x x { -audio/x-pn-multirate-realaudio logical stream&logical-audio/x-pn-multirate-realaudio Z Z ěMČďDňŽŔ ˜ ASMRuleBook €#($Bandwidth < 8000),AverageBandwidth=6000,Priority=5;#($Bandwidth < 8000),AverageBandwidth=0,Priority=5,OnDepend="0", OffDepend="0";#($Bandwidth >= 8000) && ($Bandwidth < 44100),AverageBandwidth=8000,Priority=5;#($Bandwidth >= 8000) && ($Bandwidth < 44100),AverageBandwidth=0,Priority=5,OnDepend="2", OffDepend="2";#($Bandwidth >= 44100) && ($Bandwidth < 96468),AverageBandwidth=44100,Priority=5;#($Bandwidth >= 44100) && ($Bandwidth < 96468),AverageBandwidth=0,Priority=5,OnDepend="4", OffDepend="4";#($Bandwidth >= 96468),AverageBandwidth=96468,Priority=5;#($Bandwidth >= 96468),AverageBandwidth=0,Priority=5,OnDepend="6", OffDepend="6"; $ SeekGreaterOnSwitch - RMFF 1.0 Flags % MinimumSwitchOverlap Č EndTime r-MDPR fileinfological-fileinfo k k Content Rating q Audiences [16k Substream for 28k Dial-up;28k Dial-up;56k Dial-up;256k DSL or Cable;768k DSL or Cable; audioMode music . Creation Date 11/22/2007 13:43:23 R Generated By 9Helix DNA Producer SDK 10.0 for Windows, Build 10.0.0.72 2 Modification Date 11/22/2007 13:52:23 videoMode sharp Ű ASMRuleBook Ă#($Bandwidth < 20000),Stream9Bandwidth = 10000, Stream10Bandwidth = 6000;#($Bandwidth >= 20000) && ($Bandwidth < 34000),Stream9Bandwidth = 12000, Stream10Bandwidth = 8000;#($Bandwidth >= 34000) && ($Bandwidth < 225000),Stream9Bandwidth = 26000, Stream10Bandwidth = 8000;#($Bandwidth >= 225000) && ($Bandwidth < 1000000),Stream9Bandwidth = 180900, Stream10Bandwidth = 44100;#($Bandwidth >= 1000000),Stream9Bandwidth = 903532, Stream10Bandwidth = 96468;MDPR z ' ' V Ă qŕVideo Streamvideo/x-pn-multirate-realvideo " "VIDORV40Đ@ @ € MDPR z .ŕ .ŕ V ľ qVideo Streamvideo/x-pn-multirate-realvideo " "VIDORV40Đ@ @ € MDPR z e e V Ő qVideo Streamvideo/x-pn-multirate-realvideo " "VIDORV40Đ@ @ € MDPR z ¤ ¤ { * Video Streamvideo/x-pn-multirate-realvideo " "VIDORV40Đ@ @ € MDPR z l l > Ő Video Streamvideo/x-pn-multirate-realvideo " "VIDORV40Đ@ H @ € MDPR p p Audio Streamaudio/x-pn-multirate-realaudio V.ra .ra5 F ŻČ @ @ genrcook MDPR @ @ Audio Streamaudio/x-pn-multirate-realaudio V.ra .ra5 F ę` @ @ genrcook MDPR D D € € Audio Streamaudio/x-pn-multirate-realaudio ^.ra .ra5 N € ţ € € D D genrcook % MDPR x x x x Audio Streamaudio/x-pn-multirate-realaudio ^.ra .ra5 N x 6 x D D genrcook % MDPR z ' ' V Ă Video Streamvideo/x-pn-multirate-realvideo " "VIDORV40Đ@ @ € CONT A www.spankingserver.com Diseno Media HPS (C) 2007 DAT
Sample file:Code:.RMF PROP 2 Đ Đ x =őş‚ MDPR p d d : x = dVideo Streamvideo/x-pn-realvideo " "VIDORV40` @ € MDPR x x x x = ńAudio Streamaudio/x-pn-realaudio ^.ra .ra5 N x < < x D D genrcook % MDPR Š logical-fileinfo L L ) Audiences 512k DSL or Cable; audioMode music - Creation Date 5/26/2007 21:26:14 4 Generated By Easy RealMedia Tools V1.8x 1 Modification Date 5/26/2007 21:26:14 videoMode normal $ Email rick@redcheek.net ( HomeWeb http://redcheek.net CONT (C) 2004 DATA
http://www.sendspace.com/file/za4nla
http://depositfiles.org/files/j5eu3dujc
http://ulozto.cz/xCHHyc4M/pain4fem-lea-2-rm
Anyone have any idea? Preferably... replace the header?
PS. tried to replace the header, the file play, but as a very small size vid AND there is nothing visible in it and the sound is just crazy and so... So change of the header make it possible, I just need to do it right
On a side note, the video is not exactly for the fainthearted, so, beware when trying to play it...
PS2. GSpot failed on the video:
Results 1 to 19 of 19
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
BTW, followed one advice and tried VLC, however on W2k I'm version limited to v1.0.5 and it gives this:
...so if that should be it, then I did not care anymore
At least 640x480 pixels, for christ sake!
Re-encode them if you want to play them on anything other than a computer.
FormatFactory worked. Almost wish it hadn't.
Forgot to mention: PotPlayer plays them, also. None of the MPC builds will.Last edited by transporterfan; 27th Apr 2013 at 16:51.
Sounds interesting, I give it a try. As for the content of the vid, well, I did not put out this w/o a reason: "the video is not exactly for the fainthearted, so, beware"... So you should not complain about it
Unfortunately, the latest MS visual C++ 2010 SP1 did not work on Win2k SP4, nor on WinXP, so with version of Format Factory run using MS visual C++ 2008 ...? And where to get it?"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
Oh, I wasn't complaining.
Your system is seriously outdated (yes, I know you are aware). I am not sure what build of FormatFactory, if any, will run on it.
You can try one of the very early builds from here:
https://www.videohelp.com/tools/Format-Factory/old-versions#download
Nothing else I tried (many) worked. Even FFmpeg choked, as did anything which incorporated it.
I have a feeling the video is ok but the audio channels are confusing most of the software converters. -
Well, got a bunch of those vids, so...
Anyway, I grab a MS visual C++ 2008 - this install fine on XP machine. And then choosed to download bunch of the older versions of Format Factory and tried 2.15 - worked. Tried 2.20 - worked. Dunno if there is any reason to go higher, tough. The setup for the conversion is very basic, I would like to directly change the lame settings, for example add a low-pass filter to counter the camera pitch, but I bet this won't be even in much more recent versions, right?
Now I just have to choose between avi/xvid and mkv/h264 conversion, as the vids are 720x576@24fps (full PAL with weird framerate) and the h264 look, surprisingly, notably worser, while having 30 089kBy Xvid vs 30 878kBy h264. Interesting. Also h264 encode in two pases, but the bricks are far ughlier. Xvid wins, time to start mass conversion
I've taken a look at the pesky
file, and it looks like it has multiple video and audio streams.
Otherwise, it was actually muxed in a very-weird way.
Since I am no expert at RealMedia things,...
ffmpeg cannot remux it.
A freeware RMVB muxer crashes while trying to remux the damn thing.
Gabest's RealMedia Splitter refuses it.
LAV Splitter accepts it, but then LAV Video shows only a tiny frozen frame containing only noise
AV Splitter crashes.
MKVmerge says the input file has zero tracks.
Mplayer plays the video, but outputs no audio
Yes. It has three audio streams, but I couldn't spend the time examining them. I found one other converter which would convert but the audio lagged by about 2 seconds.
I tried VLC, but only up to v1.0.5 as more recent versions did not work on Win2k. Never the less, problems are fixed with the conversion! Hoooray!
As far as the original files playback goes, I have no idea, what the hell they expected users to play them with. Perhaps Real Player... but that it is. I'm certain these files have no more that one video and audio track, as their converted size to Xvid is just a bit smaller, that the original filesize... so... It is interesting file to test the abilities of many programs
Just so you know, GSpot's support for any formats/containers other than AVI/.divx or MPEG is rather minimal, or work-in-progress. You're better off using, say, MediaInfo, or something else to get info on your video files if they're not AVI/.divx/MPEG.
Plus, the picture wasn't resizable, anyway.
To this day, I've never found a method that works for converting RealVideo AND is consistent.
(Yes, even VLC. Something that works for one file may not work for all of them, or I'll have an issue like out-of-sync sound and have to try a different known-to-work method.
(Of course, it could be just me...) Real may have inadvertently invented the best copy protection of all.
If cameras add ten pounds, why would people want to eat them? -
WHY are these old videos in Real Media format anyway?
I only know of 2 reasons to use Real.
1) The person who made the video is REALLY REALLY stupid.
2) People who are into anime often use the weirdest and crappiest video formats available for it. This is because some of these people fall under reason #1.
You have my sympathy that you have "plenty of videos" in this format.
I hope you understand Real is just about the worst quality video codec ever invented, so even if you are able to convert these, they're probably going to look terrible. -
Actually, when converted, they looks pretty good
But most RealMedia files I can play using the RM Alternative codecs - just these had to be converted.
BTW, many even big pornosites used RealMedia in the past...."I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
I wouldn't say the conversion "fixed" the problem, IMHO the conversion is just a workaround. The actual solution would be a *flawless* remux, which, AFAIK and until now, is not possible through the available freeware tools. Regarding the sample file you uploaded, Mplayer detects 4 audio streams and 4 video streams inside it. I've managed to decompress the audio stream that has the highest quality, but I haven't managed to do a "perfect" remux of the 4th video stream. Mencoder was able to rewrap the video in an AVI container, but it was unable to create the keyframe index in the output.
So I had to remove the duplicate frames in the AVI remux, generate a timecode table, recompress the decoded audio, and use the option "index all the video frames" in MKVmerge.
I dubt that this effort is could be justified - but you seems to really get on it! But when the videostream end up in mkv - will that make it playable with just RealMedia alternative codecs...?
http://www.sendspace.com/file/tufidq
http://ulozto.cz/xrstyA8/real-alternative-codecs-2-02-lite-exe
I somewaht doubt it, but - we see?"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
So far, only a RealMedia Splitter can connect to the RealPlayer decoders.
Anyway, and to whom this may interest, I will post a link to a sample file A.S.A.P.
P.S.: done.
Code:http://www.mediafire.com/?cb92d64d9d2yhc7
Thanks for your effort, but the video did not play. It is 700k bigger that the Xvid version I produced, yet it just did not play there. The BSplayer says that this is a "Unknown file format (RV40)" and that it is. I should mention that *.mkv files play fine there w/o a glitch...
But I dubt the result is nicer that mine:
...but you can compare. I can't.Code:http://www.mediafire.com/?4819lhnt3peb50z
The MKV I uploaded plays fine in MPlayer, PotPlayer and MPC-HC --- they work because they have (or can use) an UP-TO-DATE Matroska demuxer.
I already knew Haali Media Splitter doesn't support RV40 in "VfW-mode", and now you tell me VLC is b0rked too
So, why you use something that you known is useless and unplayable? Unless there is a better Haali Media Splitter, then you just can't use something, that is broken by default...
I did not tell you, that VLC is broken too - I did not tried VLC, because last version I could try is like 1.0.5 or so... tested, yes, it play. Excet this error on opening the file:
...but that it is. In VLC 1.0.5 is can and will play. However the quality is par to par to the Xvid I produce, so, there is no point using MKV (much less broken MKV) over classic Xvid avi witch play anywhere w/o troubles.No suitable decoder module:
VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
This one lack audio and when seeking - then horrible artefacts appear on the screen... so, really not a choice
PS. more recent version of VLC did not support Win2k, so I can use them."I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config
what is the most playable avi format?
By gil900 in forum EditingReplies: 13Last Post: 15th Mar 2013, 20:38 -
Convering wmv to mp4 to make it playable on HDTV
By Bencuri in forum Video ConversionReplies: 8Last Post: 27th Aug 2012, 16:42 -
need help with HDConvertToX to make avi that is 1hr+ playable in DVD
By lett303 in forum Video ConversionReplies: 0Last Post: 6th Oct 2010, 14:30 -
Help convert avi to WD HD Player -Playable format
By anbures in forum Video ConversionReplies: 1Last Post: 7th Nov 2009, 05:27 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21
