Results 1 to 9 of 9
    Feb 2006
    Hi everyone. I tried to decrease the bitrate of a MP4 in Handbrake using pretty much default settings for everything beside the avg bitrate with turbo & 2-pass. And I noticed that most of the MP4s I edit has issues with seeking the video. Not sure if seeking is the technical term but what I mean is going to a specific time in the video. If I try to seek 30 secs ahead, there's probably a 1 sec pause before the video actually starts playing. If I try to seek maybe 20 mins ahead, there's ~5 sec pause before playing. The video isn't out of sync but it just seems to need to buffer every time I try to seek. Does anyone have any fixes for this, setting I need to change, or maybe another open source editor I can use? I want to keep everything the same as source except decreasing the bitrate.
    Here's a mediainfo for the vid but this issue is for most of the mp4 i try to edit:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    Duration : 29mn 36s
    Overall bit rate : 4 073 Kbps
    Writing application : Lavf53.29.100
    Video
    Format : AVC
    Format profile : Main@L3.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 29mn 36s
    Bit rate : 4 000 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 60.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.072
    Stream size : 847 MiB (98%)
    Writing library : x264 core 120 r2120 0c7dab9
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=5 / psy=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 29mn 36s
    Bit rate mode : Constant
    Bit rate : 64.1 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 17ms
    Stream size : 13.6 MiB (2%)
    Language : English
    Oct 2005
    666th portal
    what are you playing them with?
  3. keyint=300
    Longer max keyframe intervals are proportional to longer seektimes
    Besides trying other playback software and hardware to rule out playback issues , reducing --keyint will improve slow seek latency . The "cost" of reducing the max interval is worse compression. So since you were doing 2pass avg bitrate, the quality will decrease slightly
    Feb 2006
    I'm playing with windows media player
    Feb 2006
    The media info I posted was actually the source file. After conversion I noticed that keyint=600. If there a way to change this in Handbrake?
    I tried on laptop too with wmp and it has the delay too. It doesn't have the delay on vlc but for some reason any video I try seeking in vlc is distorted/pixelated video for a few seconds before returning to normal. However, that's a separate issue.
  6. Originally Posted by imdaman View Post
    Try adding keyint=x in the advanced tab commandline box, separated by colon from the previous command, where "x" is the value
    https://trac.handbrake.fr/wiki/x264Options
    600 would be a 10sec max keyframe interval for 60fps video . If you want faster seeks try 1-2 seconds, so 60 or 120
    So just add onto the existing commands
    :keyint=120
    (or whatever value you choose)
    Then it's more likely a playback issue or at least a combination of software and long --keyint value . You can try SMPlayer, MPCHC, Potplayer, many others... WMP isn't known as a very good player
  7. Many players have a "fast seek" option to work around this problem. Instead of seeking to the exact frame you want they seek to the nearest key frame. VLC has such a setting, for example.
    Feb 2006
    Thanks for the help poisondeathray! I was able to reduce the keyint to be the same as the source. Although there is still a little pause, I'm fine with it.
  9. In case you are wondering, most high compression codecs get a lot of their compression by not repeating parts of the picture that don't change from frame to frame. So in a talking head shot on a static background one frame will encode the entire picture (an I frame, or keyframe) but the next several frames (P and B frames) will only include the changes due to the moving lips/head of the speaker. Ie, the encoded video says "this frame is the same as the last frame, except for these changes..." Eventually the encoder will create another I frame followed by a bunch more P and B frames. That distance between I frames is the GOP size, or keyframe interval (keyint in x264).
    When seeking to the middle of a GOP, to reconstruct that frame the decoder must first decompress the keyframe before the requested frame, then add in all the changes for the B and P frames up to the requested frame. With long GOPs and large frame sizes that can take quite a while. So seeking to frame 599 of a 600 frame GOP requires decompressing 599 frames before the frame can be shown to you.
    There are two ways around the problem: using shorter GOPs will work for all players but you get less effective compression (large files in constant quality encodes, less quality with bitrate based encodes). Or you can use a player with a fast seek mode -- it doesn't seek to exactly the frame you specified but the nearest keyframe. For playback that usually fine. For video editing it's catastrophic.
    Actually, there's a third way around the problem: get a faster CPU or graphics card, depending on which is doing the decoding!
