Is there another free ware product that does what imgburn does? I just bought some verbatim disks and got the "Unable to find any cells for layer break Do you want to continue?" What does this mean? Is there settings for this ? Where do I set them ? Is there something that can do what this does (make a playable disk) like image burn does?? how do cut a video_TS directory in have and get the information and burn it on 2 dvd so they are playable on a computer dvd ram or home dvd player? John
Imgburn normally finds them. If there is more than one posible break it will allow you to choose one.
If it can not find one there is something pretty cookie about the files you are trying to burn.
These are standard 1gig vob files with chapters and not one big > 4 gig vob ?
The split in to two disk method is well documented in the forum - there may also be guides. Search and check. Again, you need standard vob files etc. -
All except the last 2 are .99GB, the first file is 1.09GB, the last two are 720MB 153MB What do I use to split them?
John -
Well 1.09 GB is a non-standard size.
Try this:
http://www.dvdshrink.info/splitting-v2-3.php
But do try and find these yourself.
Can ImgBurn burn DVD-9 to DVD-5 and Main Movie only?
By coody in forum DVD RippingReplies: 22Last Post: 1st Jan 2014, 09:14 -
Burning video to DVD with ImgBurn, why does it burn twice ?
By chris_2012 in forum Authoring (DVD)Replies: 15Last Post: 9th Mar 2013, 12:49 -
Question about how ImgBurn reckons disk space
By Seeker47 in forum Authoring (DVD)Replies: 3Last Post: 10th Feb 2012, 16:38 -
How to use ImgBurn to burn mkv files in DVD
By carlmart in forum Video ConversionReplies: 3Last Post: 30th Sep 2011, 21:09 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 02:12
