What I'm looking for is an automated way to identify is a file uses pc or tv scale.
I know I can look of the histogram of a file using:
Code:ffplay -i "h:\TestClips&Co\test - clip.m2ts" -vf histogram -an -snproblem is to automate this I would need the histogram output in the console.Code:histogram AVOptions: mode <int> ..FV.. set histogram mode (from 0 to 3) levels ..FV.. standard histogram waveform ..FV.. per row/column luminance graph color ..FV.. chroma values in vectorscope color2 ..FV.. chroma values in vectorscope level_height <int> ..FV.. set level height (from 50 to 2048) scale_height <int> ..FV.. set scale height (from 0 to 40) step <int> ..FV.. set waveform step value (from 1 to 255) waveform_mode <int> ..FV.. set waveform mode (from 0 to 1) row ..FV.. column ..FV.. display_mode <int> ..FV.. set display mode (from 0 to 1) parade ..FV.. overlay ..FV..
-> does anyone know a way to:
a. get the output on the console
or
b. an alternative method to get the histogram infos of a file as console output
Cu Selur
Results 1 to 1 of 1
Index Out of Range
By bessen69 in forum DVD RippingReplies: 6Last Post: 25th May 2010, 08:34 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
real automatic level correction based on histogram?
By kopmjj in forum RestorationReplies: 22Last Post: 3rd Apr 2010, 22:27 -
10 min max file for YouTube
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2010, 07:59 -
Is there a Min/Max limit for I, B & P frames for NTSC DVD ?
By Movie-Maker in forum Newbie / General discussionsReplies: 13Last Post: 6th Nov 2008, 13:51
