I'm using tsMuxer to make the blu-ray file and Ashampoo to burn. But only one out of five tries has worked.
The Avengers works all others do not...
LOGS...
WORKING MKV file
General
Unique ID : 229891503814235100637681580142641422273 (0xACF37E3CD303B04D9F8E7008056E1FC1)
Complete name : E:\Video\Action Adventure SiFi\The Avengers.mkv
Format : Matroska
Format version : Version 2
File size : 14.7 GiB
Duration : 2h 22mn
Overall bit rate : 14.8 Mbps
Encoded date : UTC 2012-08-25 09:37:51
Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 22mn
Bit rate : 13.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.261
Stream size : 12.9 GiB (88%)
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=10 / psy=1 / psy_rd=1.06:0.08 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=192 / rc=crf / mbtree=1 / crf=16.5 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:0.90
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 22mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.51 GiB (10%)
Default : Yes
Forced : No
General
Unique ID : 232521410777209118541271838691056878323 (0xAEEDFEA96C72026DBB97F497DDBB02F3)
Complete name : D:\Torrents\Superman.Unbound.2013.1080p.WEB-DL.DD5.1.H.264-YFN\Superman Unbound 1080p.mkv
Format : Matroska
File size : 3.06 GiB
Duration : 1h 15mn
Overall bit rate : 5 826 Kbps
Encoded date : UTC 2013-04-23 05:55:33
Writing application : mkvmerge v6.1.0 ('Old Devil') built on Mar 2 2013 14:32:37
Writing library : libebml v1.3.0 + libmatroska v1.4.0
NOT WORKING INFO MKV file
Video
Format : AVC
Format profile : High@L4.0
Duration : 1h 15mn
Width : 1 918 pixels
Height : 1 078 pixels
Color space : YUV
Bit depth : 8 bits
Title : H.264
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 15mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 207 MiB (7%)
Title : DD5.1 - English
Language : English
Default : Yes
Forced : No
tsMuxer files info ...
WORKING folder
General
Complete name : E:\Video\Action Adventure SiFi\testforBLURAY\The Avengers\BACKUP\CLIPINF\00000.clpi
Format : Blu-ray Clip info
File size : 17.7 KiB
Video
Format : AVC
Audio
Format : DTS
General
Complete name : E:\Video\Action Adventure SiFi\testforBLURAY\The Avengers\BACKUP\index.bdmv
Format : Blu-ray Index
File size : 120 Bytes
General
Complete name : E:\Video\Action Adventure SiFi\testforBLURAY\The Avengers\BACKUP\MovieObject.bdmv
Format : Blu-ray Movie object
File size : 290 Bytes
General
Complete name : E:\Video\Action Adventure SiFi\testforBLURAY\The Avengers\BACKUP\PLAYLIST\00000.mpls
Format : Blu-ray Playlist
File size : 692 Bytes
Duration : 2h 22mn
Overall bit rate : 1 bps
Video
Format : AVC
Duration : 2h 22mn
Audio
Format : DTS
Duration : 2h 22mn
General
Complete name : E:\Video\Action Adventure SiFi\testforBLURAY\The Avengers\CLIPINF\00000.clpi
Duration : 2h 22mn
Overall bit rate : 15.9 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 2h 22mn
Bit rate mode : Variable
Bit rate : 13.8 Mbps
Maximum bit rate : 40.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.277
Stream size : 13.7 GiB (86%)
Language : English
Source : 00000.m2ts
Audio
Menu ID : 1 (0x1)
Format : DTS
Mode : 16
Codec ID : 130
Duration : 2h 22mn
Bit depth : 24 bits
Stream size : 1.51 GiB (9%)
Source : 00000.m2ts
NOT WORKING folder
General
Complete name : M:\tsMuxer\Movietest
Format : Blu-ray movie
Duration : 1h 15mn
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 1h 15mn
Bit rate : 5 261 Kbps
Color space : YUV
Bit depth : 8 bits
Stream size : 2.76 GiB (89%)
Source : 00000.m2ts
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 15mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Language : English / English
dialnorm : -27
dialnorm/String : -27 dB
compr : -0.28
compr/String : -0.28 dB
bsid : 8
dialnorm_Average : -27
dialnorm_Average/String : -27 dB
dialnorm_Minimum : -27
dialnorm_Minimum/String : -27 dB
dialnorm_Maximum : -27
dialnorm_Maximum/String : -27 dB
dialnorm_Count : 321
compr_Average : 5.54
compr_Average/String : 5.54 dB
compr_Minimum : -0.28
compr_Minimum/String : -0.28 dB
compr_Maximum : 6.02
compr_Maximum/String : 6.02 dB
compr_Count : 321
dynrng_Average : 5.52
dynrng_Average/String : 5.52 dB
dynrng_Minimum : 0.00
dynrng_Minimum/String : 0.00 dB
dynrng_Maximum : 6.02
dynrng_Maximum/String : 6.02 dB
dynrng_Count : 321
format_identifier : AC-3
Source : 00000.m2ts
The stream folder on the not working ones seem to have and extra file called 01900, the non working ones will play but only with audio the screen is black.
I have tried to use Xillisoft to change to resolution and that removed the extra file (01900), then handbrake because tsmuxer could not use the audio even though it was AC3,but then there was a sound issues, it was in and out.
NOT WORKING Audio but pitcure file
General
Complete name : M:\Video Edits\Superman Unbound 1080p(1)-1.m4v
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.50 GiB
Duration : 1h 15mn
Overall bit rate : 2 851 Kbps
Encoded date : UTC 2013-04-25 02:06:38
Tagged date : UTC 2013-04-25 03:01:58
Writing application : HandBrake 0.9.8 2012071700
Video
Format : AVC
Codec ID : avc1
Duration : 1h 15mn
Bit rate : 2 847 Kbps
Frame rate mode : Variable
Minimum frame rate : 23.419 fps
Maximum frame rate : 24.390 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.057
Stream size : 1.50 GiB (100%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 41s
Bit rate : 4 070 bps
Maximum bit rate : 20.9 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : 83ms
Stream size : 50.6 KiB (0%)
Language : English
Tagged date : UTC 2013-04-25 03:01:56
	You should enable 'bluray_compat' if you want to produce Blu-ray conform content using x264, also see: http://www.x264bluray.com/.
	tsmuxer CANNOT change your video and audio input. This means that if something in your video and audio is not valid for BluRay, it cannot change it.
 Your file that isn't working in the last example uses AAC audio and AAC audio is not valid for BluRay.
 Your files that have 1918x1078 resolution are likely not working because your player doesn't like that they are not 1920x1080. You may be able to get tsmuxer to use 1920x1080 as the resolution by working with the settings, but as I have never tried to make a BluRay using video where both the horizontal and vertical resolutions were not up to BluRay specs, I have never tried to do that.
  VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 22:34
  Issues Ripping Blu-Rays (Audio out of Sync)By mhmedia in forum Blu-ray RippingReplies: 10Last Post: 12th Dec 2012, 08:04
  anybody knows those blu-rays brands?By angel40204 in forum MediaReplies: 1Last Post: 6th Oct 2009, 19:00
  Can i use a blu-ray reader to Rip my Blu-rays ?By fairwind in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2008, 12:04
  can i use a blu-ray reader to rip my blu-rays?By fairwind in forum DVD & Blu-ray WritersReplies: 2Last Post: 28th Nov 2008, 14:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
