good day
over the last few days i have been trying to change avi videos into a different codec
i have 3 that work on the device that i have and i have used gspot to look into the videos so i can see what codec they use, so i downloaded virtualdub and selected xvid and followed a guide about how to do it but still the video wont play on the device
i'm not sure if it is only the video and audio codec that is important or is it also the resolution of the video as i noticed that the videos that work are *x352 so i made the res also *x352 but still they wont play.
until i found another guide that was pointing out that frame rate is also important.
please can someone help me
maybe later i can post the gspot info's
Results 1 to 9 of 9
ok thanks
here is info on the one video that does work.
General
Complete name : H:\test.avi
Format : AVI
File size : 704 MiB
Duration : 1h 28mn
Overall bit rate : 1 111 Kbps
Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library : VirtualDubMod build 2178/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 28mn
Bit rate : 970 Kbps
Width : 608 pixels
Height : 352 pixels
Display aspect ratio : 1.727
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.181
Stream size : 614 MiB (87%)
Writing library : XviD 1.1.0 Beta2 (UTC 2005-04-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 28mn
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 81.1 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 241 ms
Writing library : LAME3.96r
Encoding settings : -m j -V 4 -q 2 -lowpass 17.5 --abr 128
Language : English
here is one that does not want to work
General
Complete name : H:\holiday.avi
Format : AVI
File size : 1.23 GiB
Duration : 1h 14mn
Overall bit rate : 2 358 Kbps
Movie name : holiday
Writing application : Lavf52.17.0
Original source form/Name : holiday
Video
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Duration : 1h 14mn
Bit rate : 2 217 Kbps
Width : 1 024 pixels
Height : 574 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.151
Stream size : 1.15 GiB (94%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 14mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Stream size : 68.2 MiB (5%)
the device is called a mp5 i think it is a fake pspLast edited by ang3lus; 25th Apr 2013 at 11:31.
Many devices that play "avi" files, like some DVD players, are restricted to SD, so will be limited to 720*576.
Your second unplayable file is 1024*574.
See this sticky -
https://forum.videohelp.com/threads/290800-My-DivX-DVD-Player-can-t-play-my-avi-DivX-xvid-video -
I've heard it prefers MP4 video. Use Video to Video converter, load in a video and when the window pops up to choose a profile, click on 'Sony' and then select 'Sony PSP MPEG-4 Video'. Edit the profile settings in the boxes on the right if you want to. If that works...great...if not try one of the other settings.
This converter also has a lot of generic AVI profiles to experiment with.
Tip: use a clip or VERY short movie as a test file, else you could be waiting a while.
how to convert lossless avi codec for iPad?
By shun in forum Video ConversionReplies: 5Last Post: 19th Dec 2012, 04:13 -
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
Convert H264 to AVI (PicVideo codec)
By dandaka in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 03:15 -
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 12:54
