    Apr 2013
    Australia
    Hi, please excuse this as I am a newbie if this has been answered prior or I am in the wrong section.
    After using Any DVD to copy to hard disk, BD Info to get the play stream, then tsMuxeR GUI to output it via M2TS muxing. I am getting either sound with commentary from the directors, no matter what combination I seem to select or no sound at all.
    Can you suggest how to strip the commentary out? I tried to use eac3to but could not get it to work, some lines on the command promp window flashes and then closes and does nothing). I do not have Nero ACC encorder but the AVS4You suite.
    Regards and thanxs in advance.
  2. Use BD Rebuilder, Clown BD or MakeMKV to seperate the individual streams. And use the Search to find Guides.
    Blue-ray structure is a lot more complicated than DVD and it takes a while to get your head around it.
