Results 1 to 30 of 30
  1. What is the best way to burn mp4 file containing 3D movie to DVD to be played in DVD player without any loss of quality?
  2. Member Cornucopia's Avatar
    What kind of player? Settop or software?
    Playing as DVD-Video format or as some other more generic multimedia data file (such as your MP4)?
    "Without any loss of quality" isn't very likely.
    More info please...
  3. What kind of player? Settop or software?
    Using setup player not a software
    file info:
    General
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 1.80 GiB
    Duration : 1h 42mn
    Overall bit rate : 2 508 Kbps
    Encoded date : UTC 2012-11-30 08:46:56
    Tagged date : UTC 2012-11-30 08:46:56
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : avc1
    Duration : 1h 42mn
    Bit rate : 2 412 Kbps
    Maximum bit rate : 12.0 Mbps
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.065
    Stream size : 1.73 GiB (96%)
    Writing library : x264 core 125 r2200 999b753
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2412 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Tagged date : UTC 2012-11-30 08:47:54
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 42mn
    Bit rate mode : Variable
    Bit rate : 96.0 Kbps
    Maximum bit rate : 136 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 70.5 MiB (4%)
    Encoded date : UTC 2012-11-30 08:47:49
    Any suggestions will be appreciated
  4. Banned
    Freedonia
    Nothing in your file is valid for DVD, so you'll have to convert everything. You will lose quality for sure. This is more work than I would ever do, so somebody else is going to have to help you with that.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    try avstodvd
  6. how about if the mp4 file contains 3D movie, after copying the mp4 file into DVD, will it be possible to play the 3D movie in the 3D enabled DVD player
  7. Banned
    Freedonia
    There's no standard for 3D on DVD so 3D DVD players don't exist.
    If you did find a DVD player that could play your MP4 file, the odds of it playing a file with a resolution above 720x560 (you have 1920x800) are extremely low.
    You might be able to play the file on a 3D BluRay player if you burn it to a DVD disc without conversion, but at no point in your thread have you talked about 3D BluRay player.
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    you really need a 3d hdtv and 3d capable blu-ray player to do 3d in a watchable/enjoyable format. the old SD tv red/blue glasses really don't work well.
  9. Member Cornucopia's Avatar
    Let's assume for argument's sake that you already have a 3DTV...
    To view a Full-Quality 3D movie AUTOMATICALLY, you would need 3D Blu-rays & a 3D Blu-ray player. That's ALL. The only way.**
    If you can give a little on the Full-Quality or the Automatic engagement to 3D, you have a whole lot more options:
    • 3DBD converted to SbS/TaB media file (could be MP4, MKV, AVI, etc). The file is stored either on external HDD or Flashdrive/USBstick and played via the TV itself or general media player or disc player (Blu-ray or DVD) that supports those external media. You'd need to manually engage and adjust the 3D to select the layout format appropriate for how the file was encoded.
    • That kind of file or similar file from different source, including streaming websites that support 3D such as YT & Vimeo, played via HTPC using either StereoscopicPlayer/3DVisionPlayer (giving you lots of output layout options) or via VLC/MPCHD, etc (giving you only the layout option it was encoded as). Similar manual adjustment is required.
    • Reception of OTA/Dish/Sat/Cable channels that transmit in stereoscopic via a settop box, with similar manual adjustment.
    You could also ALWAYS use any of those files converted from their native layout format into the lowest common denominator (aka ANAGLYPH - Red & Cyan, etc) and watch as 3D with the appropriate glasses, EVEN ON A 2DTV, but as was mentioned, you will be losing a lot of the quality and extra experience when you do. Plus, it makes your eyes tired MUCH more quickly than modern, full-color, improved 3D methods (Active LC shutterglasses or Passive Polarized lenses).
    **This has changed slightly, depending upon what you consider FullHD3D and where your source is from...
  10. The 3D movie file is in mp4 format (side by side), this file is stored in USB stick and I want to play it by sticking it into the USB port on my Panasonic 3D Blu-ray player, it could not display because the video's format was MP4 and apparently the player can play only avi, do I need here to convert it to avi if so how? for other normal 2D files I am using boilsoft video converter I am able to convert up to 1080P HD Videos, but how its possible in case of 3D
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the side by side video is the same as any other mp4. it just has 2 copies of the video in each frame. you can convert it to any format you want. it's the tv that converts it to 3d. you can push the 3d button while watching anything. so your boilsoft thing or any other converter will do the job.
  12. Member Cornucopia's Avatar
    And you MAY not even need to reencode. Might be just a matter of demuxing the mp4 into its constituent streams and then remuxing into avi.
    Dec 2008
    I just converted a 3D from a MP4 to VOB with convertxtodvd link-http://www.vso-software.fr/products/convert_x_to_dvd/
    It will convert it and burn it to a DVD and you will lose some quality. On my DVD they come out great. I just converted a MP4 3D and burned it. Will give it to my brother because I do not have a 3 D TV. So I wont know yet if it works. I can say when I play the movie it has a split screen.
    Untill I see if my brother can play it on his 3D TV.
  14. Member Cornucopia's Avatar
    If you DON'T have a 3DTV, it will always stay just a silly split-screen video in 2D. If you wanted to watch it "in 3D" on your 2D TV set, you would have to first re-encode it as an Anaglyph, as mentioned before.
    If your brother has a 3DTV, (and assuming you properly re-encoded & authored & played the DVD), he should be able to play the DVD, manually switch his TV into 3D mode - using SbS as the 3D input source choice - and should see it fine in 3D.
    Dec 2008
    Scott When I burned the DVD 3D and play on my computer it does have a split screen.
    The software convertxtodvd will convert just about any file even MKV.
    Here are all the formats.
    VIDEO Popular
    .avi
    .divx
    .flv
    .mpg
    .mkv
    .wmv
    .xvid
    .mp4
    .mov
    Blu-rays
    DVDs
    AviSynth Script
    .avs
    Digital Video Recording
    .dvr-ms
    .wmr
    DivX
    .avi
    .divx
    High Definition Video
    .evo
    .m2ts
    .mts
    Flash Video
    .flv
    .swf
    Matroska
    .mkv
    MPEG
    .dat
    .ifo
    .m2p
    .m4v
    .mpeg
    .mpg
    .ps
    .tod
    .ts
    .vob
    MPEG-4 / QuickTime
    .3gp
    .m4a
    .mov
    .mp4
    Nullsoft Video
    .nsv
    Ogg Vorbis / Theora
    .ogg
    .ogm
    Real Media (with external DLL)
    .ram
    .rm
    .rmv
    .rmvb
    .rv
    Windows Media
    .asf
    .wm
    .wmv
    XviD
    .avi
    .xvid
    AUDIO Popular
    .ac3
    .dts
    .mp3
    .wav
    .wma
    Free Lossless Audio Codec
    .flac
    Matroska
    .mka
    Monkey's Audio
    .ape
    MPEG Audio
    .mp1
    .mp2
    .mpa
    .mpga
    .mpu
    MPEG-4 Audio
    .aac
    .m4a
    .ma4
    Musepack
    .mpc
    Ogg Vorbis / Theora
    .ogg
    Real Media / Real Audio
    .ra
    .ram
    .rm
    Uncompressed
    .aif
    .wav
    .wave
    Other
    .au
    SUBTITLE Internal and external subtitles supported: with color and font selection, and supports tags like italic, bold. Turn on/off with DVD player remote control.
    Graphical
    .idx
    .sub
    pgs
    Text
    .ass
    .srt
    .ssa
    Other
    - Subtitles in MOV files
    - DVB Subtitles
    - DVD Subtitles
    - Blu-ray Subtitles
    I hope this helps you.
  16. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Oy Vey
  17. Member Cornucopia's Avatar
    @lalmeada, it is NOT the conversion to filetypes/codecs that I was referring to, but rather the 3D-layout types. By and large, containers & codecs are ignorant of 3D-layout (there are exceptions).
    But,
    Since you already converted to the appropriate VOB for DVD use, and you intend to display on your brother's 3DTV via DVD settop player, you are done. No need to give me some huge rundown of available types, etc.: I could care less about that.
  18. Originally Posted by lalmeada View Post
    My TV won't go into 3D mode unless the resolution is 720p or greater. I'd imagine most TVs would be the same. Therefore to play SBS 3D video converted to DVD format, I'd imagine the DVD player would have to be capable of upscaling. Or you'd need to use a Bluray player, but then you probably wouldn't convert to DVD format for that.
    Out of curiosity, I took a SBS 3D video and used Avisynth to open it while resizing it to 720x576 (PAL DVD dimensions). I displayed it full screen with MPC-HC set to output a 16:9 aspect ratio and the TV set to 1080p. I basically simulated a conversion to DVD, without any re-encoding loss of quality. It looked pretty blurry at the much lower resolution. 720x480 (NTSC) would no doubt look worse. And of course I could ensure the aspect ratio remained correct. The DVD version might display in a slightly wider than 16:9 aspect ratio which would make it look more blurry.
    I wouldn't bother myself. Even at 1080p, 3D can be a bit hard on the eyes at times, but when it's also blurry.....
    The 3D movie file is in mp4 format (side by side), this file is stored in USB stick and I want to play it by sticking it into the USB port on my Panasonic 3D Blu-ray player, it could not display because the video's format was MP4 and apparently the player can play only avi.
    That'd be unusual..... only playing AVI. Not impossible, but unusual. What's the model of the Bluray player?
    Your brother's 3D TV..... does it have a built in media player? If it's not terribly old it probably does. Pretty much every TV manufactured these days has a built in USB media player which will play all sort of files.
    Feb 2015
    California
    Hello I have question and read the below Thread from Scott and others,
    https://forum.videohelp.com/threads/355528-Need-to-Burn-3D-MP4-to-DVD
    I understand the MP4 to DVD but is the same process used to convert from MP4
    to MKV or DivX so my 3d player and 3D TV will play it ??
    Here is my electronic used
    Asus BD Writer/Player ASUS BW-12D1S-U Lite External Blu-Ray Drive with USB 3.0
    Disc Types Disc Diameters: 4.7/3.1" (12.0/8.0 cm)
    Disc Formats: Audio CD, Video CD, CD-I, CD-Extra, Photo CD, CD-Text, CD-ROM/XA, Multi-session CD, BD video, DVD Video
    Read Speed BD-R: 8x
    BD-RE: 8x
    BD-ROM: 8x
    BD-R (DL): 8x
    BD-RE (DL): 6x
    BD-ROM (DL): 8x
    DVD+R: 16x
    DVD-R: 16x
    DVD+RW: 12x
    DVD-RW: 12x
    DVD-ROM: 16x
    DVD+R (DL): 12x
    DVD-R (DL): 12x
    DVD-ROM (DL): 12x
    DVD-RAM: 5x
    CD-R: 40x
    CD-RW: 24x
    CD-ROM: 40x
    DVD Video Playback: 5x
    VCD Playback: 9.3x
    Audio CD Playback: 9.3x
    Write Speed BD-R: 12x
    BD-R (DL): 8x
    BD-RE: 2x
    BD-RE (DL): 2x
    DVD+R: 16x
    DVD-R: 16x
    DVD+RW: 8x
    DVD-RW: 6x
    DVD+R (DL): 8x
    DVD-R (DL): 8x
    DVD-RAM: 5x
    CD-R: 40x
    CD-RW: 24x
    Writing Mode BD-RE: Random write
    BD-R: Sequential write
    DVD+R and DVD+R (DL): Sequential write
    DVD-R and DVD-R (DL): DAO/incremental recording
    DVD+RW: Random write
    DVD-RW: DAO/restricted overwrite/incremental recording
    DVD-RAM: Random write
    CD-R/RW: DAO/TAO/SAO/packet write
    Access Time BD (SL/DL): 250 ms
    DVD: 170 ms
    CD: 150 ms
    Pansaonic 3D 50" Plasma TC-PG50GT50 TV
    Technology 3D
    Plasma panel technology Panasonic Plasma Panel
    Native resolution 1920 x 1080
    Resolution 1080p
    Refresh rate 600 Hz
    Aspect ratio 16:9
    24p technology 24p Cinematic Playback, 3D 24p Cinema Smoother
    Progressive Scan progressive scanning (line doubling)
    Widescreen widescreen
    HDCP compatible yes
    3D Features THX 3D certified
    Video Interface Component, composite, HDMI
    HDCP Compatible Yes
    Panasonic DMPBDT31- Player
    My DVD player plays these formats, via DVD and 3D Disc
    BD Disc Player plays formats- DivX and MKV
    USB devices plays formats MKV -MP3- DivX
    MP4 3D Movie I have them in file format, but can't play them in
    the panasonic 3d player on to the Panasonic 3D TV Plasma
    I want to write them on to 3d format disc or file format but Panasonic
    player only reads MKV or DivX formats to the TV from what i read.
    How do I copy the MP4 computer file using what program to get the job done ?
    I looked at so many programs not sure which one to use to get the
    job done an need to learn what process and programs will make the
    changes if it even possible.
    I kinda understand what Videohelp_man asked and is trying to do
    I don't mind loss as its part of the process,
    Format is MP4 reading its file info not sure but need to know what the
    best program to have for viewing file format.
    I thank everybodys input to this above thread. It helps me better understand...
    now just to know what program best to use to get the job done to make MP4 files
    and transfer or copy them in the panasonic format to play them ? to DKV or DivX
    format to play them and write them so the Panasonic player format
    and watch them ?
    "" Originally Posted by lalmeada View Post
    On my DVD they come out great. I just converted a MP4 3D and burned it""
    [/I]
    is the the best way to do it or am I missing something i need to learn yet.
    Thanks to anybody who takes the time for me as I'm a 100% disabled US
    Veteran learning this process.
    Ron
  20. Banned
    Oct 2014
    Northern California
    Huh?
    3D DVD's?
    Feb 2015
    California
    I guess Newpball
    I'm a new person here so what is the problem ? ?
    If I didn't say something correct, why not teach me
    instead of acting like you know some thing nobody
    else knows or your the only one who has all the
    answers here. Give some intelligence type response
    not play like your lost ? ?
  22. Member Cornucopia's Avatar
    Huh?
    3D DVD's?
    Already answered/explained in posts #7 and #9 above, which you would have known if you had bothered to read.
    @jetskr1la, please post a detailed MediaInfo report of one of those mp4 files...
    Also, visually does it play (on your PC) in side-by-side layout or what?
  23. Member
    Feb 2015
    California
    Hello Scott
    Yes it plays on my Dell Desktop with 3.5 GHZ CPU
    side by side dual screens. with standard dvd play from
    computer. But I have a ASUS ext DVD BD player i have
    not tried it from there yet. I don't think the ASUS is a blu ray
    player just a writer player but maybe wrong. I can get the picture
    from the computer to my 3D TV vis hdmi from computer to hdmi inputs
    but need to try finding a way to force the 3D picture for the 3D TV to
    change the format to real 3D.
    I have and view now 2d with side by side pictures in HD quality no problems.
    I read this but was not sure if post #7 & 9 pertained to my exact situation or not.
    Its why I asked for somebodies help and guidance.
    I apologize and mis understood whats going on like I said, I'm new here learning
    Thanks for your time Scott
    I also down loaded a section from somebody 19 page discussion about 3D movies
    and am learning from this also.
    I connected my PC with HDMI outputs to my 3d TV with the
    same side by side pictures .. i will try and force my Panasonic
    to play the 3d pictures if i can figure out how to do that.
    Thanks for your time again Scott
    Ron
  24. Member
    Feb 2015
    California
    will get back with a detailed media report about one of the MP4 file here ASAP also
    thanks
  25. Member
    Feb 2015
    California
    Here is the Mediainfo
    General
    Complete name : 3D\Gravity (2013) [3D] [HSBS]\Gravity.2013.1080p.3D.HSBS.BluRay.x264.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 1.25 GiB
    Duration : 1h 30mn
    Overall bit rate : 1 961 Kbps
    Encoded date : UTC 2014-02-07 15:19:40
    Tagged date : UTC 2014-02-07 15:19:40
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 1h 30mn
    Bit rate : 1 864 Kbps
    Maximum bit rate : 9 898 Kbps
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.037
    Stream size : 1.18 GiB (95%)
    Writing library : x264 core 135 r2 f0c1c53
    Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=36 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weight b=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1864 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Tagged date : UTC 2014-02-07 15:19:48
    Color primaries : BT.709
    Matrix coefficients : BT.709
    Color range : Limited
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 30mn
    Bit rate : 93.3 Kbps
    Maximum bit rate : 105 Kbps
    Stream size : 60.7 MiB (5%)
    Language : English
    Encoded date : UTC 2014-02-07 15:19:47
    General
    Complete name : Gravity (2013) [3D] [HSBS]\Thumbs.db
    File size : 23.5 KiB
    General
    Complete name
    Format : 128 KiB
    Format : JPEG
    Width : 350 pixels
    Height : 500 pixels
    Color space : YUV
    Chroma subsampling : 4:4:4
    Bit depth : 8 bits
    Stream size : 128 KiB (100%)
  26. Member
    Feb 2015
    California
    Of course I will use the 3d TV and 3D player and in hopes it will play the 3D Movie file to make it all work.
    As I know it takes all 3 of the 3D unit to work together, to play the 3d. But i need to take the MP4 file and
    convert it to MKV or DivX to play on my Panasonic 3D player to send it to the Plasma 3d TV, just hope the
    automatic sensing changes to 3D mode on the TV.
    Ron
  27. Member
    Feb 2015
    California
    Can the MP4 file be converted to MKV or DivX format AND THEN COPIED TO THE
    THE FLASH DISC and work with the 3D PLAYER TO WORK WITH THE TV Panasonic ?
    Or how can I convert the MP4 to disc to MKV format so I can burn it on the disc and work
    and play with both Panasonic dvd player and 3D TV. can MP4 be converted to work as a
    MKV file format and saved to 8.7 DL disc.
    Thanks for any help you experts ?
  28. Member
    Feb 2015
    California
    Hello
    The Panasonic plays MKV and DivX format only with FLASH DISC PLUGGED INTO THE PANASONIC 3D PLAYER ONLY,
    THAT WHY IT CANT PLAY THE AVI FORMAT.
    Playable discs/Cards/USB devices
    Type Logo examples Type detail Playable contents
    (�� 39)
    BD-Video Video
    BD-RE
    Video
    JPEG/
    MPO (3D still picture)
    BD-R
    Video
    DivX® [BDT310/]
    MKV
    DVD-Video Video
    DVD-R
    Video
    AVCHD
    DivX® [BDT310/]
    MKV
    MP3
    JPEG/
    DVD-R DL
    DVD-RW Video
    AVCHD
    — +R/+RW/+R DL
    Music CD Music [CD-DA]
    — CD-R
    CD-RW
    DivX® [BDT310/210_for_Canada]
    MKV
    Music [CD-DA]
    MP3
    JPEG/
    SD Memory Card (from 8 MB to 2 GB)
    SDHC Memory Card (from 4 GB to 32 GB)
    SDXC Memory Card (48 GB, 64 GB)
    (Compatible with both mini and micro types)
    MPEG2
    AVCHD
    JPEG/
    — USB devices
    (up to 2 TB)
    DivX® [BDT310]
    MKV
    MP3
    JPEG/
    BD
    DVD
    CD
    SD
    USB
  29. Member Cornucopia's Avatar
    You don't want to use the DivX format unless you have to, as it is no longer the best option.
    Just so you understand, a "divx" file is actually (usually) a divx (aka xvid aka mpeg4-part2)-encoded video stream + audio stream (various formats) encapsulated in an *.AVI file. The file might have the extension renamed to *.DIVX, but it still is in essence an AVI.
    Note that newer "DIVX" versions have abandoned the AVI container base and are now using the MKV container base. They have also migrated from MPEG4-part2 encoding of the video to h.264/AVC (aka MPEG4-part10)-encoding (with HEVC encoding in the wings).
    What I suggest you do is remux your current MP4(s) to MKV. Do NOT re-encode! That would lose quality. You have a number of options for apps:
    MKVMergeGUI
    AVIDemux (copy mode)
    XVid4psp (copy mode)
    MP42MKVac3 (this one re-encodes the audio, though)
    but one of the simplest and most straightforward ones is ffmpeg, IMO.
    This batch script should work for you...
    for %%a in ("*.mp4") do ffmpeg -i "%%a" -c copy -metadata stereo_mode=left_right "%%~na.mkv"
    pause
    What this will NOT do is set the mk3d metadata tag to HSbS. This may or may NOT be necessary in order for your player app to auto recognize the file as being a particular type of 3D and auto engage 3D mode on your TV. If it is necessary, you will need to (manually) set the meta tag in something like MakeMKV...
    ...just added the metadata that SHOULD take care of the mk3d tagging for you in ffmpeg. What you might still want to try is changing the extension from *.MKV to *.MK3D, if necessary.
  30. Member
    Feb 2015
    California
    Thank you for your time and i will start out by doing as you said to try.
    Have a good one
    Ron
