Hi all,
I am not interested at all in the "TV" part of a DVR, I am just looking for a DVR with RCA inputs in order to capture old VHS. I am looking for a standalone box, not needing a computer.
I used a Lacie Lacinema Black Record for the first 30 or so tapes, but it really has a bad interface, and zero config options (output format... etc.)
What would be your suggestions for a good DVR for this. I have hundreds of tapes in different formats from the 50's til today to capture. I am looking for a simple solution not requiring re-encoding or any work in the computer after.
Thanks,
Zoqwvysp
You didn't get an answer because you gave no in formation about what part of the world you live in. I'll assume you don't buy your stuff in North America, because few people in N.A. these days can afford to spend money on LaCie products. If you don't care about the TV functions, why did you buy a DVR? Ever heard of a DVD recorder? http://www.whathifi.com/reviews/home-cinema/dvd-recorders
If you live in NTSC country you can try Walmart.Last edited by sanlyn; 28th Mar 2014 at 18:41.
Sorry, I should have mentioned I am in Canada.
I did buy the Lacie in France though. I moved around a lot lately
I am not interested in DVD recorder, I would like to have them stored directly on a hard drive (I will later cut and edit all, and I do not trust DVD's as a storage for long term)
I did see this Magnavox on Walmart US (although it is not available in Canada). I was wondering if there were other options.
Thanks anyway,
Simo -
If you don't want the hard-drive equipped Magnavox DVD recorders, there may be some specialty retailers carrying "international" or "multi-system" DVD recorders with a hard drive that can record both PAL and NTSC video signals from composite or S-Video connections. I don't know what retailers in Canada might carry such merchandise, so here is a link to a recorder at a US retailer for illustration purposes.
http://www.bhphotovideo.com/c/product/659769-REG/Panasonic_DMR_EH59GA_K_DMR_EH59GA_K_M...B_HDD_DVD.html
I hope you realize that dubbing to DVD is the only way to offload recordings from nearly every DVD recorder's hard drive because the recordings are almost invariably encrypted.
Can an S-VHS Player and S-Video Output Cable Benefit Standard-VHS Capture?
By Avagadro1 in forum Capturing and VCRReplies: 34Last Post: 5th Dec 2012, 18:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Capture DVR/VHS to laptop?
By SOHkat in forum Capturing and VCRReplies: 3Last Post: 22nd Aug 2011, 12:40 -
Best outboard consumer capture device today? VHS, LD, camcorder and HD DVR
By cosmichippo in forum Capturing and VCRReplies: 4Last Post: 11th May 2010, 13:46 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16
