Hi,
I just bought a Toshiba dvd player SD3300 (at Best Buy 39.99$) and there is a way to have every region on the DVD hacks part of this website.
BUT the owner's manual shows SD3300KC2 instead of simply SD3300. Do you think it is the same? I tried, but it is does not work!
Is it the same or did I make the things badly?
Thank you to help me and excuse my very bad english!
Torvisse
There are only two answers.
You did it wrong.
Toshiba changed the firmware or something else inside the player. -
So, I did wrong, you are wright!
I tried again et now it is works!
Thank you!
Well, I am not lucky. It works one time, to try and when I wanted to watch a dvd, it did not work even in region 1... So maybe the «KC2» after the SD3300 model means that you cannot turn it into a multizone player...
I read that someone turn his SD3300KC to a multizone. I would like to know if someone did it on a SD3300KC2 (maybe it was the dvd player I bought that was no good).
I just change my CD player SD3300KC2 and the new one is worsth thant the other. I put a dvd (region 1) inside : «no disc». I tried to fix the code : it fits for Region 1 but nut for a disc Region 2. I put a Region 1 disc again : «no disc».
Is somebody could help me about this cd player??
Excuse my bad english and thanks for your advice!Last edited by Torvisse; 26th Apr 2013 at 14:52.
Hacking DVD5
By SomeRelax in forum MediaReplies: 8Last Post: 8th Nov 2011, 05:49 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Hacking a Sony RDX650
By Khelben in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jun 2009, 17:08 -
Newbie, and considering hacking Toshiba HD-A2 to play PAL discs
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Jun 2008, 18:30 -
By Puppets86 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jun 2008, 22:42
