How can I lossless convert an *.flv video to *.mp4 container ?
At first I thought the following will do the job:
ffmpeg -i sss.flv -vcodec copy -acodec copy ttt.mp4
but when i do this I get the following error:
[NULL @ 000000000206c560] Unable to find a suitable output format for 'D:\tmp\ttt.mp4)'
D:\tmp\ttt.mp4): Invalid argument
Whats wrong?
I am using the newest (static) ffmpeg under 64bit Win7. ffmpeg works fine for other jobs.
Peter
General
Complete name : D:\todo\intsrc.flv
Format : Flash Video
File size : 95.1 MiB
Duration : 8mn 17s
Overall bit rate : 1 604 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=25
Codec ID : 7
Duration : 8mn 17s
Bit rate mode : Variable
Maximum bit rate : 1 500 Kbps
Width : 852 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : AAC
Format profile : LC
Codec ID : 10
Duration : 8mn 17s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Lossless convert video from MP4 to AVI ?
By pxstein in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2012, 10:03 -
Convert mp4 to lossless avi?
By vampypiano in forum Video ConversionReplies: 2Last Post: 30th Jan 2012, 06:00 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
lossless flv to mp4
By Driber in forum Video ConversionReplies: 3Last Post: 9th Aug 2010, 17:01 -
can ffmpeg convert SWF to FLV ?
By yair2008 in forum Video ConversionReplies: 3Last Post: 1st Dec 2008, 20:44
