If I rip with crf, how could I know the compressibility then make judgment?
In the past, I always use crf 19.0 and it normally will give me reasonable size with good video quality. But somtimes, it sure give a size much bigger. So, is there any way to know the compressibility of the source DVD? And suppose I know it then, how could I set the crf number precisely?
If the source is very uncompressible, how could I make it compressible? By filter? (MCTemporalDenoise?)
If the source is very compressible, then what number should I us for crf? (17.5? 18.0?)
You want to set the CRF to make the size you want? You can't. Set the bitrate instead and run two passes for your size. With CRF encoding the sizes might be all over the place. With 2-pass bitrate encoding the quality might be all over the place.
You could run a sort of compression test first to judge its compressibility. For example, adding this to your AviSynth script:So, is there any way to know the compressibility of the source DVD?
SelectRangeEvery(280,14)
will encode 14 frames out of every 280, or 5% of the full movie. From that you can get a general idea of the compressibility of the full movie.
Yes, by filter.If the source is very uncompressible, how could I make it compressible? By filter?
Only you can answer that question.If the source is very compressible, then what number should I us for crf? (17.5? 18.0?) -
I've tried to use filter, but this seems to occur error.
I've put my script this way, but the MeGUI error:Code:SetMemoryMax(512) SetMTMode(3) LoadPlugin("D:\Program Files\Megui\tools\dgindex\DGDecode.dll") DGDecode_mpeg2source("E:\yazhi\s\Tender.Is.the.Night.1962.DVDRip.x264.AC3.d2v") Import("D:\Program Files\Megui\tools\avisynth_plugin\MCTemporalDenoise.v1.4.20.avs") MT(""" MCTemporalDenoise(settings="very low",sigma=1,chroma=true,enhance=false,sharp=false,GPU=false) """,threads=0,overlap=8) SetMTMode(2)
"There is no function named MT"
I've already install the Avisynth 2.6, and I've replace the avisynth.dll downloaded from the doom9 page. And I haven't found any "MT.dll" in that zip pack. -
Remove this from your script. This is the 6th line in what you wrote.
MT("""
That will fix the problem.
Also, just so you know, it's not necessary to pretend to be a woman to get help here. The odds of a woman being interested in video enough to use AviSynth are very very low. I am talking about that picture you have under your name. -
I'm not "pretend" to be a woman or anything. And that woman is not some ordinary people, she is JOAN FONTAINE for god's sake.
And this forum named "videohelp", isn't it? Am I get it wrong or sth? Isn't it suppose to be a place where to pick out questions and post?
Anyway, glad to meet your guy say this words.
Re-encode using CRF lower than source's original CRF
By Anonymous54873 in forum Newbie / General discussionsReplies: 13Last Post: 13th Jan 2013, 21:40 -
CRF B-frames
By Legiit in forum Blu-ray RippingReplies: 3Last Post: 14th Feb 2012, 09:44 -
pepsi hit with 1.26 billion dollar default judgment
By deadrats in forum Off topicReplies: 1Last Post: 28th Oct 2009, 18:49 -
AutoGk Stuck In Vista On Compressibility Test
By nhgawe in forum DVD RippingReplies: 4Last Post: 6th Jun 2009, 22:27 -
Auto GK Compressibility Test is taking forever need help!
By AirBoyzT in forum DVD RippingReplies: 2Last Post: 16th Aug 2008, 01:54
