Hi everyone,
I'm a newbie to editing and I tried out about Sony Vegas and Adobe Premiere on my friend's computer but I can't seem to use TS files in neither.
I'm looking into buying one because I can only afford one. If I want to use Vegas I'll probably use my friend's pc.
My main question is though is there anyway
1) I can use TS files because when I tried putting them in they couldn't work?
2) If I can't use TS files is there something that can convert the TS files into one of the formats SV or AP uses (whilst keeping the quality of the file?)
I would really appreciate your help and it would be much appreciated
Results 1 to 9 of 9
Here it is. Thanks for your help.
General
Complete name
Format : MPEG-TS
Format profile : No PAT/PMT
File size : 2.00 GiB
Duration : 1h 17mn
Overall bit rate : 3 702 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=4, N=12
Duration : 1h 17mn
Bit rate : 3 325 Kbps
Maximum bit rate : 3 200 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.321
Stream size : 1.80 GiB (90%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Mode : Joint stereo
Mode extension : Intensity Stereo + MS Stereo
Duration : 1h 17mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -374ms
Stream size : 106 MiB (5%) -
This is not an ordinary transport stream ; without a program association table (PAT) or program map table (PMT) most programs will not be able to open it . Set top recorders, cable boxes often record streams like this.
Does it play in something like VLC ? If it does, you should be able to convert it to something else in VLC or ffmpeg
If it doesn't, then if you can upload a small sample someone might be able find a workaround for you -
I would demux (de-multiplex) that file into its constituent audio+video stream files and then remux (re-multiplex) those into a standard MPEG2-PS (*.MPG) file.
You might even be able to get away with demuxing only and loading the elementary streams directly into your editor.
Problem would be if even the demuxing app won't read the *.TS file(s) (because of the aforementioned missing PAT/PMT). If so, try: MPEG2Repair, VideoReDo Plus, DGIndex, ProjectX, TSDoctor, TSConverter, TS4NP, to repair the TS first.
Scott -
I guess it would greatly depend upon the level of corruption of the video...
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 06:02 -
Editing AVCHD (M2TS) with Adobe Premier
By rancineb in forum Video ConversionReplies: 33Last Post: 29th Jan 2009, 21:23 -
Problems with Adobe Premier Elements
By jeffprice74 in forum EditingReplies: 4Last Post: 21st Jun 2008, 10:24 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 22:01 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 12:57
