I'm using virtualdub to capture some old VHS tapes - I run the videos from my VCR and then convert it to digital signal through an ADVC110.
A couple of years ago when I started doing it, I ran into a problem: video is interlaced in overlay mode. In preview mode none of the preview accelerations can't be accessed (vdub cannot display incoming video as it is in an unsupported format) ... Captured files are OK though, they are all deinterlaced, but the interlaced overlay is annoying, especially if you want to sit and watch the captured videos, noting down time codes fore specific events....
I remember googling a solution which helped, and the result was that both overlay and preview were deinterlaced...
BUT... I recently had to reinstall windows, and with them every software I use, including virtualdub. So I'm facing the same broblem with interlaced overlay, but I have forgotten the right solution....
Million thanks in advance for any help!
Results 1 to 1 of 1
Capture two video streams at once (overlay?)
By exon in forum Capturing and VCRReplies: 1Last Post: 27th Nov 2012, 16:30 -
Overlay on VirtualDub shows as a raining garble of color, Preview worksFINE
By RisunEtsija in forum Capturing and VCRReplies: 0Last Post: 2nd Sep 2012, 07:59 -
Virtualdub Interlaced Export?
By elliot_123 in forum Newbie / General discussionsReplies: 9Last Post: 29th May 2012, 03:39 -
Interlaced YV12 chroma messes up between AviSynth and VirtualDub
By Neimo in forum Video ConversionReplies: 6Last Post: 21st Apr 2010, 19:30 -
Capture twice and overlay
By sphinx99 in forum RestorationReplies: 11Last Post: 15th Mar 2010, 05:02
