Hello,
I am starting a short film project in my film school, and since I am not expert in editing,and I have to edit it myself, I found myself kinda lost in the pixel ratios.
I do understand the general differences that TVs use rectangular ones when computers use the square ones, my problems are:
1- do you choose the pixel ratio while shooting or it happens in post (is it related to the shooting format, HD, HDV,DV...?) or it is just related to editing options;
2- what is best to chose specially that my short will be projected via a pc mostly, and may be if I'm lucky it might be screened on a tv later on.
3-does the square pixel work good in TV broadcasting or it ruins the video.
I am using canon 5D for shooting.
I hope somone can help me with these questions, thanks alot in advance.
You don't directly choose the pixel aspect ratio. It's more a matter of what format you shoot in. You don't have any choice. The Canon 5D only shoots square pixel 1920x1080 (16:9 HD) and 640x480 (4:3 SD).
If you remain in HD, your job is somewhat easier, because they primarily use ONLY 1:1 PAR (aka square pixels). There are variations (HDV, Sony HDCam) but they're not anywhere as common as most HD material, unlike the Wild West of SD ratios.
If you stay 1920x1080 (with square pixels) from start to finish in your shooting, editing, and compression/distribution, you'll be fine.
BTW, most devices that deal on a regular basis with non-square pixels will know how to properly correct for them, so creating a compliant DVD (obviously Std. Def) at 720x480 (NTSC system) or 720x576 (PAL system) will use non-square pixels, but a properly engineered DVD player will output the correct compensating info so that you will get the correct AR on screen. In these instances, it's best to stick to common, approved STANDARDS.
If you have more questions, let us know. But do give more thorough info...
converting NTSC DV 4:3 to look good in square pixels ...?
By Bansaw in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2012, 14:59 -
conversion square to non square pixels???
By jakeotr in forum Video ConversionReplies: 7Last Post: 27th Jan 2012, 00:53 -
Square pixels or 16:9 Pixel aspect ratio?
By Scherwin in forum Video ConversionReplies: 6Last Post: 18th May 2010, 12:47 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 02:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 10:20
