  1. hi can some one tell me how can i add beswwet encoder in megui . because in my audio encoder list ther isnt besweet and i want encode audio with besweet in megui . can some one help me ? tnx
  2. Doesn't MeGui use the same libraries&tools that besweet does? (mainly: sox, azid, aften)
    If you want a specific tool added to MeGui you should contact the MeGui authors,...
  3. no imean like staxrip that use besweet for audio encode , do something that megui use besweet too
  4. There should be no need for MeGui using Besweet, to be precise MeGui did use Besweet a few years ago, but since MeGui extended it's Audio processing to Avisynth input, there was no real need for Besweet, since MeGui should be able to do the stuff BeSweet does. (see: http://forum.doom9.org/showthread.php?t=106434)
