I bought Adobe Encore recently because I got tired of using pre-made menus from various programs.
Everything's fine until I tried using an mkv video because I wanted to play around with multiple audio streams.
Realizing how little I know it seems, I tried to just figure it out.
According to mediainfo....
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 49s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 120 r2120
Audio #1
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 49s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 49s
Channel(s) : 2 channels
Audio #3
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 49s
...the original mkv is 23:46 long, as well as each individual stream.
When I used mkvcleaver, since Adobe hates mkv, the 4 streams came out.....well,
the avi is 19:30, the two stereo aac's 3:21:14, and the 6 channel one @ 5:40:41.....
I assumed it was because of the multichannel for the audio, but that's more than 8 times the length of the original.
Totally lost.
Upon importing it into Premiere, the audio tracks were reading 23min again. But the video was still at 19.
It's all there, just playing at a greater fps or something.
Similar problem happened when I used AVStoDVD, both just getting the streams and muxing into a m2v.
Thus I conclude I just don't know what the hell I'm doing anymore (and I felt so good working avi's and mp4's a day ago)
Any Help explaining what I seem to be missing is appreciated.
I tried that of course, and the video is fine (seemingly), but then the audio lags.
1~3 seconds at the beginning and end, but like a whole minute in the middle.
Yea, no idea.
Ah yea, as far the video, I think that was the problem. Thanks! Totally forgot about Handbrake.
As far as audio goes, what format is less...problematic? Flac?
Audio out of sync when converting from MKV
By carlmart in forum Video ConversionReplies: 8Last Post: 22nd Dec 2012, 16:07 -
Remuxing Results in MKV Audio-Video Sync Problem
By gonwk in forum Newbie / General discussionsReplies: 5Last Post: 26th Apr 2012, 20:51 -
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 05:56 -
Mkv Audio sync problem converting to DVD
By yudopplyr in forum Video ConversionReplies: 14Last Post: 10th Dec 2011, 14:55 -
Converting mkv to dvd always results in an oversize iso
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 23:16
