So I shot an event today with my camcorder and when I import these videos into the Adobe Premiere Pro, the length of the video is wrong; the event went on for about 1 hour and 40minutes and that is exactly what shows up in the camera if I play the files on it, even in other players (BSPlayer, VLC, Zoom, MPC) the length of the footage is correct, but in adobe it somehow gets the information that the recordings are around 5hrs in length. For test purpose I have started a test encode, but since the video is in full HD and currently being on my laptop it's going to take about 14hrs for a LQ single pass encode. So I was wondering since I'm expecting for the video to be somehow wrong due to the wrong length detected by Adobe, any clues as to what might cause this?
Another note, shot quite a few events with this camera and edited them in Adobe, no problems thus far.
Cheers
What does mediainfo say about a sample source clip ? (view=>text)
What does premiere "think" the fps is (look at the clip in the clip bin) ?
Was it a continuous recording (file spanned clips) ? Did you import the clips individually or through the media browser in PP ? Is the directory structure intact (folder structure, with accessory files and metadata) ?
As a temporary workaround you could encode to a lossless intermediate (or near lossless intermediate like cineform) -
So here it is;
So the length here is OK, and yes it's a continuous shot at least most of it is (and those are exactly the ones in questions) the 1st video that I ended the recording is fine and shows up in the Adobe as is 14mins in length the 2nd, 3rd and 4th are in questions since they are a continious shot, the 5th and 6th are again OK, due to the fact that they are seperate recordings.Code:General ID : 0 (0x0) Complete name : C:\Users\Denis\Desktop\BDMV\STREAM\00002.MTS Format : BDAV Format/Info : Blu-ray Video File size : 1.90 GiB Duration : 19mn 49s Overall bit rate mode : Variable Overall bit rate : 13.7 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=12 Codec ID : 27 Duration : 19mn 49s Bit rate mode : Variable Bit rate : 12.9 Mbps Maximum bit rate : 16.0 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.333 Stream size : 1.79 GiB (94%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 19mn 49s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 36.3 MiB (2%)
Here is the copy paste from Adobe for the same file;
So as far as I can tell the 3 files in question are TOGETHER in length supposed to be 56min and 41sec, but Adobe detects each as to be this long.Code:File Path: C:\Users\Denis\Desktop\BDMV\STREAM\00002.MTS Type: MPEG Movie File Size: 1,9 GB Image Size: 1440 x 1080 Frame Rate: 25,00 Source Audio Format: 48000 Hz - compressed - Stereo Project Audio Format: 48000 Hz - 32 bit floating point - Stereo Total Duration: 00:56:41:19 Pixel Aspect Ratio: 1,3333
AVCHD camcorders record video in chunks of 2GB maximum each. Depending on the bitrate used, each *.mts file in the \STREAM folder can be anywhere from 10 to 20mins or longer. Two consecutive presses of the camcorder start/stop button can therefore produce a string of consecutively numbered *.mts files, each about 2GB, if the recording duration between those presses is longer than about what 2GB can fit into. Though these files can be be fished out of the \STREAM folder standalone and be used as is, metadata about how they are related to each other is contained in the \CLIPINF and \PLAYLIST folders. This metadata is dynamic and changes according to how new recordings are subsequently made with the camcorder.
When an NLE program like Adobe Premiere Pro is used to open a camcorder \BDMV folder that has all of the \CLIPINFO, \STREAM, and \PLAYLIST folders intact, it recognizes information in them to join together *.mts clips that were shot within the two consecutive presses of the start/stop button seamlessly into a whole new file. It can be confusing because this new virtual file is now the correct length of the joined 2GB *.mts chunks, but with no new file name. So for example, on a continuous 1hr shot which produced four files 0000.mts to 0003.mts, opening or dragging to the timeline any of these files in Premiere Pro will be like opening that whole continuous shot from 0000.mts to 0003.mts as one seamless whole. Opening 0000.mts, or 0002, 0003, or 0001.mts will have the same effect, so just dragging 0000.mts onto the timeline is enough. In the Premiere import bins, it will be easy to note which files have been joined: all of them will have the same long aggregated length.
This works as intended in that the files are joined seamlessly. If only the *.mts files were discretely opened in Premiere (taken from somewhere without the \CLIPINFO and \PLAYLIST folders included) and were added manually in the timeline, there is an audio glitch where they are joined, and frames may be dropped as well.
For me, I prefer importing only the *.mts files into Premiere, being careful not to drag the \CLIPINFO, etc. folders as well into the HDD capture drive. I like to retain them as the original 2GB *.mts chunks, which makes it easier for me to move them on the timeline a few frames to and fro to best align and sync them with an externally recorded audio track.Last edited by turk690; 21st Apr 2013 at 16:22.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Is it possible to add more video slots on adobe cs6 premiere pro?
By kakarotoni in forum EditingReplies: 9Last Post: 10th Sep 2014, 20:41 -
How to import Srt subtitle to adobe premiere Cs6
By vivabarca in forum EditingReplies: 4Last Post: 31st Mar 2013, 18:43 -
on MAC - converting MTS file to something I can import to Premier Pro CS6
By bdaul in forum MacReplies: 1Last Post: 19th Jan 2013, 06:12 -
Laptop for Adobe Premiere Pro CS6
By Amira_S in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2012, 11:01 -
Shortening time of imported video in Adobe Premiere Pro CS6
By vivabarca in forum EditingReplies: 2Last Post: 25th Jul 2012, 06:14
