What is the best way to extract a single frame from a Blu-ray with no or least amount of compression? I am getting a frame from a movie printed as a poster for my friends birthday on B0 paper (1.4 METRES WIDE!) so I need the highest quality rip I can possibly get. The place I am getting it printed requires it to be in pdf format and recommends CMYK colour mode. I can probably figure out that part once I have the lossless frame but any recommendations on how to get it to that point would be helpful. I am able to decrypt the Blu-ray with no problems also.
Results 1 to 12 of 12
i haven't tested this but it seems to me that you could open up the decrypted bluray with avidemux, use the cut function to choose only one frame (an I frame) of the image you want and then export that using no compression (i believe it would be saved in raw format). i don't know how to go from raw to pdf, i'm guessing most image manipulation apps like paint.net can probably do that.
Don't mean to be negative here but is this legal? I mean are you going to some kind of production house for this large print? Or is this a friend that has a specialized printer at home?
Reason for asking is professional businesses will be forced to follow copyrights and assuming this is a professionally made bluray there will be copyrights involved.
But if this is homemade from a hd handycam or something it will be ok.
I would just make sure you can do this without legal troubles. And as I pointed out if this is a private individual it shouldn't be a problem from a "fair use" aspect. Not making money from it in other words. But if you go to some professional studio there could be implications here for you or for them.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
He is talking about making a single poster for a friends birthday party, not making a 1000 copies to sell.
I don't think anyone would care.printed as a poster for my friends birthday
I used to get special or limited edition 2"/3" CD's that came in little cardboard sleeves.
So I could put them into standard jewel cases I would take the cardboard sleeves to the local printer shop and have them color photocopy them and enlarge them to fit in a standard cd jewel case, then I stored away the original little cardboard sleeves.
I have also taken custom hidef artwork from famous bands and had them made into posters for myself to hang up in frames.
No one is going to care unless you get caught making 1000's of them and start selling them. -
I tried opening up 3 different blurays and avidemux crashed each time. I updated to latest avidemux with little success I even tried the latest beta build...no dice. I imagine the printscreen method would not be the best way to get the image I want but I gues it is a last resort... Any other program suggestions/ways to get avidemux to work?
As for the legal part I guess I'll just see when I try to get them to print it. Hopefully it will all be okay.
btw this is the picture I am getting printed xD
http://images.fandango.com/MDCsite/images/featured/201110/jurassic-park-blu-ray-shirtl...ian-malcom.jpg
Imagine that but 1.4 metres wide
http://answers.yahoo.com/question/index?qid=20080412220631AAM4Pw9
Screenshot method seems like what I want. -
I don't think anyone has mentioned using virtualdub.
For this test I still have a bluray rip on my harddrive and I used vdubmod and directshowsource to open the largest m2ts file in the stream folder which is the main movie itself. Go to the video tab and select snapshot source frame to save the still. It can go frame by frame.
The file formats you have to choose from are:
targa
bmp
png
This test was using vdubmod 1.5.10.2 and a recent bluray movie release from last year (ripped in whole with anydvdhd).
Another version of virtualdub that has the directshowsource filter may have other file formats that you can save the image too.
Hope this helps.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Glad to help.
FYI there is an export image sequence option in virtualdub. I'm not sure if you can set it for a range to extract images or if it just dumps the whole video as a set of stills. A little more research and experimentation would work if you want a slew of stills without manually doing it over a set time period.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
How to make a single MKV from a Blu-ray (and also how to shrink it)
By Baldrick in forum User guidesReplies: 51Last Post: 27th Jan 2015, 08:49 -
faster blu-ray to dvd single layer conversion
By Steve(MS) in forum Blu-ray RippingReplies: 11Last Post: 10th Aug 2011, 21:02 -
Several blu-ray m2ts files to one single file?
By Mr Flibble in forum Blu-ray RippingReplies: 5Last Post: 14th Apr 2010, 10:34 -
Blu-Ray to single m2ts file without re-compressing
By Moondiver in forum Blu-ray RippingReplies: 8Last Post: 6th Jan 2010, 18:56 -
Multiple AVCHD's to Single Blu-ray for PS3
By hhel11 in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jul 2008, 13:29
