Results 1 to 9 of 9
  1. i`ve tried everything, this damned thing doesnt work! and the only thing i want is the 20th century fox trailer, not even 15 seconds...
    the problem: i have a (with smartripper 2.34) ripped .vob-file which i can watch without problem in windvd. i also have the needed .d2v file created with dvd2avi, but when it comes to saving as a vfapi-avi using vfapi 1.04 the only output i got is a 0 byte avi file??!!
    i tried "save as avi", too, but it is unreadable for media player or virtualdub.
    anyone got a useful hint???
    thanks, ben.
  2. same here i want to know if there is some thing done wrong or perhaps worded wrong i can t get it to work also
  3. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    How do you use VFAPI?
    I have never had this problem. Did you use DVD2AVI before? Did you have this problem before? How did you save the DVD2AVI file?
    The Dutchman
  4. yes i'ved use it b4 i save it as SAVE AS, then double click on the icon and put my d2v file in and it say done it a few seconds then i try to use and nope. please tell me how to use it.
  5. i assume u mean the VFAPI Reader Codec...
    add job->choose your .d2v project file created by dvd2avi->select OK->convert->exit....u have your homemade avi file...make sure that all the options are checked in the dialog box that appears right after u selected your .d2v file
  6. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Alupnu,
    has your problem been solved now?
    The Dutchman
  7. no. whats the homemade avi file for i can;t get it to open with any programs
  8. vfapiconv will not produce any output for me either. i have my .d2v project file from dvd2avi which i used to add a job to vfapiconv. i make sure all of the check boxes are checked. when i go to convert, it runs fine. however, i get no output file, not even a zero length one.
  9. Found this answer from user name Cart Wheel. I tried it and it worked for me. So maybe this is the same problem you guys are having. Message below:
    How are you going from VirtualDub to VFAPI? Is there a VFAPI plug-in for VirtualDub that I'm not aware of?
    One thing you should try is running "proxyoff.reg" in the aviproxy folder in your VirtualDub directory. A lot of people seem to leave proxy mode enabled, which can cause problems. Also, the latest version of VFAPI is 1.04, not 1.03.
    -Cart
    http://www.geocities.com/lukesvideo/index.html
