Hi, I'm using PowerDirector 10 to make a blu ray disk with a few movies on it. I'm having two problems, with the second being the critical one. First, when I try to add a song in the Menu Background box (the original song is "Wedding 1"), it simply won't appear in the box field. The song opens in the window where you can alter its duration and chose whether or not to fade in/out, etc., but it won't appear in the final Menu Background field. I also cannot type in this field. Is this a common problem or am I doing something wrong?
Second, and the real critical problem is this: The last movie I'm trying to add was actually produced using PowerDirector 10, and ironically, it's saying "format not supported" when I try to add the movie to the file list that I want to put on the disk. The other movies are added without problem. As I said, all of the other movies add without problem, and yet this is the only movie rendered via PowerDirector 10. It's produced as an MPEG-4, using 29.97 frame rate, 1280 X 720 resolution and a 6000 bit rate. I'm including both movie profiles for inspection, with the second being the one that says it's an incompatible format. PLEASE HELP! How can I get it into the right format, even though they both appear to have the same profile!!
MovieOne
FileType: MP4
FileSize: 2.18 GB
Video
Type:H.264 AVC
Duration:01:59:18:23
Bitrate:2.43 Mbps
Resolution:1280 X 720
FrameRate: 29.97 fps
AspectRatio: 16:9
Profile:High Profile
FrameType: Progressive
Audio
Type:AAC
SamplingRate: 44 kHz
Bitrate:192 Kbps
Channel:Stereo
MovieTwo
FileType: MP4
FileSize: 16.60 GB
Video
Type:H.264 AVC
Duration:06:28:42:18
Bitrate:5.73 Mbps
AspectRatio: 16:9
Profile:Main Profile
Audio
Type:AAC
SamplingRate: 48 kHz
Bitrate:384 Kbps
Channel:Stereo
i'd guess you have an audio problem. aac is not an allowed blu-ray audio.
Great...
... Well why would PowerDirector render it as AAC?? I'm beginning to think this program sucks... But why is it allowing the first video to be added to the file list and not the second, when they're both AAC? What audio format should I convert to? And how do I do it? Thanks again.
well if you check what is blu-ray in the upper left of the page - https://www.videohelp.com/hd - allowed audio is ac3, dts, wav. how you get pd10 to create it is up to you.
PowerDirector vs Premiere Elements
By Lothar1974 in forum Newbie / General discussionsReplies: 6Last Post: 26th Aug 2013, 07:47 -
Save splited clips in PowerDirector?
By yic17 in forum EditingReplies: 0Last Post: 16th Mar 2011, 14:49 -
powerdirector
By 160bpm in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2010, 16:25 -
Audio problem with Cyberlink PowerDirector 7
By Angela1204 in forum EditingReplies: 1Last Post: 3rd Apr 2010, 01:46 -
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2009, 23:49
