Hi All,
I have been converting some old VHSs Home Movies to DVD via a Panasonic NV GS55 Camcorder, capturing via Premiere. After I capture them Premier creates an .avi file that plays back fine (audio and video in sync) in both VLC and Windows Media Player.
But when I bring the file into a sequence in Premiere for editing the audio goes out of sync. (Not hugely out of sync...maybe a second or less)
While capturing there were some frames dropped maybe 20 or so. I guess this could be the problem but the why does the audio and video sync in VLC and WMP but not in Premiere?
Also I was able to get the audio to sync up by changing the speed of it to 100.03% (3 hour video) but then when I rendered it to an avi the audio was out of sync when I played it in VLC and WMP.
Any help is much appreciated.
	use winDV to re-capture the video. you need to set it to stop capturing on dropped frames. then restart and capture the next good part until it's done. once you have all the available parts you can join them back into one video. --
	In my experience, capturing long stretches of DV-AVI 3hrs or more with Premiere Pro nearly always creates sync issues at the tail end of that big file. I restrict capture to an hour maximum, then just string them together on the timeline. It's also infinitely easier moving and viewing/scrubbing a 13GB 1hr DV-AVI file than a 40GB 3hr file.
 Seasoned users of Premiere also do not create sequences in excess of 3hrs. It's more stable that way, it's said. Many shorter sequences can in turn be nested in one empty sequence.For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  Premiere Pro CS5 audio syncBy LordPython in forum EditingReplies: 17Last Post: 18th Oct 2011, 20:13
  ntsc dvd sync problem in premiereBy krohm in forum EditingReplies: 1Last Post: 4th Apr 2011, 07:02
  Premiere Audio Sync ProblemBy Cedrick Salizar in forum EditingReplies: 1Last Post: 11th Jan 2010, 12:01
  HD dvd conversion, audio sync problem...By BigJeebz in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 22:52
  Premiere CS3 audio sync issuesBy friz in forum EditingReplies: 5Last Post: 5th Jul 2008, 16:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
