Hi, I'm Re Authoring the blu ray of The Last of Mohicans. So I opened the 00800.m2ts (main film track) with TSmuxer and added the ac3 track of my language. Then I added the .sup subtitle track that I made with Subtitle Edit 3.3.4. Now, after muxing, If I open the m2ts with VLC I can hear my new ac3 track without problem, but subs that I muxed are shown just for an istant (0,100 ms), why? I'm sure that subs timing is correct (I spent a lot of time to sync it), so where is the problem? Is TSMuxer invalid to mux .sub file?
I'd love to work just on main .m2ts file, and after all putting the new m2ts in stream folder of my original BD.
I hope that someone can help me, thanks![]()
I know that I could use .srt subtitle, but original bd format is sup which is also able to have coloured text with some effect. Do you know some software that I can use instead of Tsmuxer to add .sup file in a .m2ts without encoding?
Subtitle Edit has only recently supported export as *.sup, and there have been some associated bugs (look at the changelog). I'm still using v. 3.2.8 and it doesn't have that option. I should update I suppose.
Anyway, try the latest version.
Alternatively, export as *.srt and convert to *.sup with easySUP. Maybe tsMuxer will like that better. Or try TsRemux.
It may be, of course, that there's a timing error somewhere, despite all your effort.Pull! Bang! Darn!
I can not add .m2ts files into TSMuxer
By yaoyao0204 in forum Blu-ray RippingReplies: 2Last Post: 25th Nov 2011, 20:00 -
MKV to M2TS w/ TSMuxer
By averageschmoe in forum Video ConversionReplies: 2Last Post: 22nd May 2011, 00:21 -
tsmuxer help with .mkv to .m2ts for PS3
By sharoo in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2011, 12:12 -
replace subtitle of blu-ray main file on tsmuxer 1.10.6 problem
By ps3z in forum Authoring (Blu-ray)Replies: 0Last Post: 8th May 2010, 14:02 -
MKV avc to m2ts via tsMuxer;1080p muxing problem for ps3. Please
By rafoolik in forum Blu-ray RippingReplies: 5Last Post: 11th Aug 2009, 17:55
