Hey I've been using my Pvr for 6 months now, but today when I decided to record, my record preview comes up black and when I click capture and then stop its says "capture fail". Also the Input resolution is now 720x480 and I can't change it.Help please!
Results 1 to 10 of 10
You tried to capture something that is NTSC.....not your native PAL video format.
Try reinstalling the drivers. I had a weird problem with my Colossus (basically the same thing you have but as an internal card rather than an external device) where it wouldn't record anything and reinstalling the drivers fixed it.
Playing/Viewing NTSC in a PAL country is no problem. Capturing/recording is a PROBLEM.
Close the capture app and then unplug the power to the HD PVR2 and plug it back in. Then try to capture again.
There's not much to do but then I can't do much anyway.
Capture Software for Hauppauge HD-PVR
By DarrellS in forum Capturing and VCRReplies: 41Last Post: 26th May 2013, 20:24 -
Hauppauge PVR-150 capture quality, help!
By granturissimus in forum Capturing and VCRReplies: 17Last Post: 19th Jul 2012, 04:21 -
Hauppauge HD PVR (Capture PC gameplay)
By TommyGun in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2010, 10:50 -
hauppauge hd pvr 1212 Capture Issues
By jwack in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2009, 21:17 -
Capture from your Hauppauge HD-PVR to your Mac
By cnolan011 in forum MacReplies: 1Last Post: 14th Jan 2009, 01:34
