Hello,
I've been looking around to see if I can find out why when you capture through composite (or s-video)
and the audio-in at the back of the card, the volume is very low. If you open the capture window
in Virtualdub and turn on the volume meters, you can see that most of the audio is between
-20 and -30 db.
I suspect it's the driver, since the card has mpeg-2 HW encoder; that's the volume that ends up in the mpg file.
Using Avermedia MCS software, there are picture adjustments, but nothing for sound.
The card does a pretty good job, but the audio really needs to be normalized post capture.
I've put in a request to the Avermedia tech support but not much so far, they sent me an older driver to try.
Anybody have any knowledge of a capture program that can increase the volume on the fly?
Can Virtualdub do it?
Have you tried looking for volume controls in the registry? Even if they are there, they may not function. But worth a shot.
record hd tv signal with m780 avermedia only get one audio
By godai in forum Capturing and VCRReplies: 30Last Post: 8th Mar 2013, 17:01 -
Dialogue Volume in LCD TV is low while action/music volume is high
By Biker Biker in forum DVB / IPTVReplies: 4Last Post: 2nd Mar 2013, 02:41 -
Is it true that if I capture on low volume then the Audio will be better?
By gil900 in forum AudioReplies: 22Last Post: 16th Feb 2013, 11:03 -
AverMedia for capturing from analog VHS
By Hilfiger48 in forum Capturing and VCRReplies: 0Last Post: 27th Aug 2012, 07:39 -
AverMedia C027 HD Capture Low Audio
By XmnwildX12 in forum Capturing and VCRReplies: 3Last Post: 29th Jun 2011, 21:03
