Ok. Suppose i want to denoise a clip with NLmeansCL(uses GPU) what changes should i make in the script? should i call the setmtmode(5,2) before calling the NLMeansCL filter?
Results 211 to 240 of 390
The setMTMode(X,Y) call is only allowed ONCE in the whole script, at the beginning, als following setMTMode-Calls only have one parameter, the mode.
Modes change only through setMtMode-Calls, so if you are already in mode 5 you do not have to switch to mode 5, if you are in example in mode 2, switching is recommend. -
What is the use of SetMemoryMax()? i've seen this used in some of the scripts of doom9 members.
read http://avisynth.org/mediawiki/Internal_functions/Control_functions -> SetMemoryMax
The encode with MT has been going on for about 15 hrs now. the encoding fps is 0.370 as of now with the placebo preset.
placebo -> http://en.wikipedia.org/wiki/Placebo
I totally don't get you 1st you want to speed up your '-preset slower' encode and then you choose '-preset placebo'. -
I'm encoding with the placebo preset so that i can compare it with the slowest preset.
There's hardly any difference between slow and placebo. Not much difference between medium and placebo. As a rough indicator here are the results of some test I ran at different presets (CRF=18, quad core i5 2500K CPU, DVD source, no filtering):
Results will vary depending on the source. And obviously, overall speed will vary depending on CPU.Code:fps bitrate ------------------------------- ultrafast 457 5066 superfast 386 3275 veryfast 260 2119 medium 82 2651 slow 52 2591 veryslow 13 2315 placebo 5 2351
I don't think so, but you can try,... SubExtractor and SubRip should be able to do it,..
Surprise, x264 too needs cpu power for encoding, who would have thought that.
And to state another obvious fact: encoding the script can't get faster than decoding the script,.. -
How do i encode an avs script with the same x264 settings, without having to type the same x264 code everytime?
i would like to use the same code for different avs files.x264 --preset placebo --crf 17.0 --qcomp 0.7 --aq-strength 0.7 --psy-rd 0.7:0.2 -o "encode.mkv" -
use a gui which supports profiles and learn to use it
or
learn how to write a batch script and write a script that does what you want
or
learn a programming language and write a small program that does what you want,.. -
Nope, my experience writing batch scripts under Windows are minimal at best, but it's not really hard to understand and with a little effort you can find some examples through the forum search and modify them to your needs.
SMdegrain has a parameter called tr(temporal radius). Will increasing the value for tr increase the quality of the denoising?
from the SMDegran script:
see: http://forum.doom9.org/showthread.php?t=152326Code:### tr [int: 1, 2, 3] ### -------------- ### Temporal radius. Select between MDegrain 1, 2 or 3. Higher is better, but also much slower. ### Default is 2.
AnonymousGuest
Here is a simple example:
Code:cls @echo off echo. SET ENCODER=E:\Apps\VideoTools\x264\x264.exe SET SOURCE=F:\Test\test.avs SET STATS=F:\Test\test.stats SET TARGET=F:\Test\test.264 SET BITRATE=6000 SET PASS1="%SOURCE%" --bitrate %BITRATE% --profile high --level 4.0 --bluray-compat --tune film --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --b-pyramid none --b-adapt 2 --no-fast-pskip --no-dct-decimate --pic-struct --vbv-bufsize 22000 --vbv-maxrate 24000 --keyint 24 --ipratio 1.1 --direct auto --threads auto --thread-input --pass 1 --slow-firstpass --subme 3 --ref 4 --me hex --trellis 0 --stats "%STATS%" --output nul SET PASS2="%SOURCE%" --bitrate %BITRATE% --profile high --level 4.0 --bluray-compat --tune film --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --b-pyramid none --b-adapt 2 --no-fast-pskip --no-dct-decimate --pic-struct --vbv-bufsize 22000 --vbv-maxrate 24000 --keyint 24 --ipratio 1.1 --direct auto --threads auto --thread-input --pass 2 --subme 9 --ref 6 --me umh --trellis 1 --stats "%STATS%" --output "%TARGET%" "%ENCODER%" %PASS1% echo. "%ENCODER%" %PASS2%
should also work as batch (not sure about the %)Code:
FOR %%A IN (*.avs) DO x264 --preset placebo --crf 17.0 --qcomp 0.7 --aq-strength 0.7 --psy-rd 0.7:0.2 --output "%%~encode.mkv" "%%~A"
AnonymousGuest
like I wrote, I'm not sure if each %% should be replaced by a single % instead, but try&error should easily solve that.
Filtering
By x264 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2013, 02:47 -
Need help filtering Jaggies
By LadyLiete in forum RestorationReplies: 12Last Post: 21st Aug 2012, 06:30 -
Filtering during MPEG capture
By TB Player in forum Capturing and VCRReplies: 9Last Post: 31st Dec 2010, 18:53 -
Questing about filtering with one of your guides
By Oni87 in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 17:26 -
Audio Filtering Program
By dawson54 in forum AudioReplies: 6Last Post: 13th May 2008, 08:10
. The fps at which x264 encodes is much slower than that what i get when i run the script in
