I've been having trouble playing .avi files in VLC from a site I regularly visit, they run like slideshows on my old laptop. Someone turned me towards Media Player Classic for it's lesser demand on the processor, and it worked!
...For one video.
The other 3 I have from the same site and same uploader load the first frame, and then just sit there even though the MPC-HC says it is "playing." Pausing and pushing play again does nothing, and stopping and pushing play again does nothing. If I skip ahead several minutes, nothing happens until I click pause, then click play again and it jumps to that frame, but still sits there doing nothing. I tried redownloading the videos, thinking the downloads just screwed up, but still the same thing.
I tried them in the K-Lite Codec Pack version of MPC-HC as well, and all 4 of the videos play, but they play at about half speed video while the audio continues normally then starts cutting out after it gets 10 seconds ahead or so. All of them play in VLC, but again they play like a slideshow, although the audio seems to work. I tried them WMP as well and they play great... for about 30 seconds, before the frame rate drops and the sound cuts out.
While searching around for something to do, I looked at the "properties" of the videos and noticed some differences.
This is the video that played fine:
While the other 3 looked like this:Format : AVI
File size : 919 MiB
Duration : 57mn 59s
Overall bit rate : 2 215 Kbps
Writing application : MEncoder 1.0rc1-4.1.2
Writing library : MPlayer
Video
Format : x264
Codec ID : x264
Duration : 57mn 59s
Bit rate : 2 012 Kbps
Width : 912 pixels
Height : 512 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Bits/(Pixel*Frame) : 0.086
Stream size : 835 MiB (91%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 57mn 59s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 79.6 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 500 ms (25.00 video frames)
Interleave, preload duration : 500 ms
Format : AVI
File size : 267 MiB
Duration : 17mn 20s
Overall bit rate : 2 157 Kbps
Video
Format : x264
Codec ID : x264
Duration : 17mn 20s
Bit rate : 1 955 Kbps
Width : 912 pixels
Height : 512 pixels
Bits/(Pixel*Frame) : 0.084
Stream size : 242 MiB (91%)
Title : q4_1.avi Video #1
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 17mn 19s
Bit rate : 192 Kbps
Stream size : 23.8 MiB (9%)
Interleave, duration : 5445 ms (272.27 video frames)
Title : q4_1.avi Audio #1
Writing library : LAME3.99.5Format : AVI
File size : 929 MiB
Duration : 58mn 47s
Overall bit rate : 2 209 Kbps
Video
Format : x264
Codec ID : x264
Duration : 58mn 47s
Bit rate : 2 007 Kbps
Width : 912 pixels
Height : 512 pixels
Stream size : 844 MiB (91%)
Title : r4_1.avi Video #1
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 58mn 47s
Bit rate : 192 Kbps
Stream size : 80.7 MiB (9%)
Interleave, duration : 10921 ms (546.04 video frames)
Title : r4_1.avi Audio #1I have bolded what I noticed as significant differences between the videos, but I have very very little understanding of these things so maybe I'm missing the mark entirely. These videos have been giving me headaches the past few days trying to find things to make them work as the site I get them from seems to be the only one where I can reliably find them, so I don't have alternatives to download in different formats.Format : AVI
File size : 878 MiB
Duration : 55mn 36s
Overall bit rate : 2 208 Kbps
Video
Format : x264
Codec ID : x264
Duration : 55mn 36s
Bit rate : 2 006 Kbps
Width : 912 pixels
Height : 512 pixels
Stream size : 798 MiB (91%)
Title : r2_1.avi Video #1
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 55mn 35s
Bit rate : 192 Kbps
Stream size : 76.4 MiB (9%)
Interleave, duration : 5460 ms (273.00 video frames)
Title : r2_1.avi Audio #1
Can anyone explain what I'm looking at here and what I need to do to bring the other 3 videos in line with the first?
Any help would be greatly appreciated, even if it's just pointing me towards another (preferably very "lite" player) as I would like to get this sorted so I can follow the videos for the rest of the year.
MPC-HC audio problems - no center channel??
By chowmein in forum Software PlayingReplies: 2Last Post: 4th Sep 2012, 20:08 -
MPC - Video problems when going fullscreen?
By czeshire in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2012, 07:02 -
MPC HC problems with 6-ch AAC audio tracks
By tufffta in forum Software PlayingReplies: 19Last Post: 1st Mar 2012, 03:47 -
MKV newbie - video slightly skips using MPC
By captenblack in forum Newbie / General discussionsReplies: 5Last Post: 25th May 2009, 19:41 -
Problems with ffdshow, MPC and .mov videos
By ziptip in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2008, 04:14
