Bitrate is large part of file size, I've posted many time before trying to find a way to keep the 1080p quality with a small file size but now I realize thats almost impossible. I was shown a bite rate calculator that help give the bitrate to use tp obtain certain file sizes. Now I see it the type of encoding that is used to help keep the high Bluray 1080p quality. As always with lowering the bite rate which lowers the file size that ultimately lowers the quality. Screen is not as bright as true Blu ray, true black not as dark with other aspect unknown to me.
Is H.264 the best for encoding blu ray to keep the high qulity of blu ray with low file size.
No, it's all of the filesize, except for a tiny bit of overhead for the container, subtitles, chapter stops, etc.
Code:File size = bitrate * running time
Bitrate doesn't effect black and bright levels. You have another problem there. Too low a bitrate results in loss of small low contrast detail, blocky artifacts, rough edges...
Yes. Some h.264 encoders are better than others. x264 is generally considered the best. And the settings you use matter too. -
You don't exactly specify what you mean by small file size. The only 1080p br rip/encode I've ever seen that was close to original quality was 16Gb in size.
I think you'd be better off downscaling to 720p if you want high quality in a decent size. I've seen some really excellent br encodes like that. They were still around 2Gb, maybe a little less. And they were done by people with a good knowledge of the settings, which do matter hugely.
I've seen br encodes to 1080p about 1Gb in size or less. They were really bad, and I seriously doubt there are any settings that would've made them any good.
I have seen 1080
How is this quality so good with such a low bitrate?!
By mmbwdpnz in forum Newbie / General discussionsReplies: 9Last Post: 9th Aug 2013, 09:15 -
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 08:21 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
