Hi, I have a 46pfl7007t/12 Philips 3D LED TV and I was wondering if I could watch a mkv movie with .pgs (sup) subs (like this https://forum.videohelp.com/images/imgfiles/ww8gzOz.jpg) from USB (external HDD)? My tv supports only this kind of subs format https://forum.videohelp.com/images/imgfiles/pKLsoAq.png , so if i have a .srt sub with same name as the movie, everything is ok, but i want the graphics like in pgs. Is there any way to do this? Because the usual pgs sub / mkv muxing using MkvMerge my TV doesn't recognize.
Thanks.
Thanks for reply. I did this way, but the quality really loses. Is this normal, or i should change some settings?
For better comparison, FULL RES. HERE
Also, after merging the subtitle format is VobSub (codec S_VOBSUB). My TV will read it (vobsub is SubViewer format or?...) ?
Thank you.Last edited by MotherOfGod; 16th Apr 2013 at 04:12.
Have you tried increase the output format resolution in bdsup2sub? Like 1080p. If it's possible. It was a long time ago I used it.
So, in my tv subtitles menu I can see the .sub file but when playing the movie - no subtitle are displayed, even the low quality one. What's might be the problem?
Can not extract PGS stream from MKV file
By gonzalu in forum SubtitleReplies: 27Last Post: 19th Aug 2016, 04:48 -
Mkv + srt to BD + pgs problem to read
By Sgt Hartman in forum SubtitleReplies: 10Last Post: 26th Jan 2013, 03:55 -
Remuxed M2TS to MKV gives PGS subtitles without language flag (with Blurip)
By Quasit in forum Video ConversionReplies: 1Last Post: 30th Nov 2010, 13:31 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 17:36
