  1. Hi!
    I am a big fan of anamorphic widescreen video, I'm often shooting with 1.33x Panasonic AG-LA7200 anamorphic lens.
    I need to make video in 2560x1080 resolution, but I don't know how to do it in popular editing programs. All I can do now is export the video I edited in the resolutions the editing software is offering me (like 1920x1080) and then convert it with Koyote Free Video Converter (which I use) reducing it size by 25% by squeezing the video to 1920x810. Koyote Free Video Converter allows to choose any video size I like, I can specify just any height and width, that's why I prefer to use it. But there is a noticeable quality reduction, and if I specify big bitrate, the files just become huge. And converting video takes time which I wouldn't like to waste. So i really want to make 2560x1080 (or any other resolution I like) video with the help of video editing program, or better edit video in that resolution. Which editing programs can do it and how?
    Also, I have a 576x720 anamorphic footage which I would like to export in wider resolution, but still, the only option I have is to widen it with my video converter which reduces quality.
    Thank you for help!
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Sony Vegas goes up to 4K resolution. Simply start a new project with the resolution you desire.
    Vegas is "resolution independent", so no matter the source, it will requantize it to the project specs. It's like music, if you have a 4/4 piece, you can upsample it to 8/4, 16/4, 32/4 or whatever.
    Use the Crop Tool to visualize the output according to different resolutions and aspect ratios.
  3. Member Cornucopia's Avatar
    I don't really understand your confusion.
    You've got an anamorphic lens, that shoots 4:3, so a normally 1920x1080 (aka 16:9 DAR) shot would encompass a full 2560x1080 anamorphic image. So shoot with that lens and a 1080i or 1080p camera. Take the data into Vegas with a 1920x1080-based project/session setting, do all your edits, then export as Lagarith (or whatever you like) at 2560x1080 (aka ~2.37:1) superwidescreen.
    Or
    Import your 1920x1080 anamorphic footage into a 2560x1080-based project, set your interpretation of the footage to be ~2.37:1 DAR, or use the Crop/FX tool to "stretch" back out your footage, so it matches the frame size. Then export at 2560x1080...
