While looking at an old cartoon series I ordered on DVD that clearly was transferred from some sort of video tape (some noticeable dropouts and dimming/color change), I've been wondering about when a low-pass filter is applied. As I understand it, video cameras would have low-pass filters built in to prevent twitter on interlaced displays...but what happens with something that was telecined (as cartoons were)?
The thing is, despite the signs of aged tape that are impossible not to notice, the picture seems to have pretty good resolution to me, to where I'm wondering if the perceived resolution is actually somehow better on this DVD set than it was on broadcast back in the day on a CRT, despite the fact that it's clearly deinterlaced SD. But that doesn't seem likely to me as I would think the content was already blurred on the original source (tapes).
Look closely at high contrast vertical edges. Do you see oversharpening halos?
Not as far as I can tell.
The main thing I'm curious about is at what point they would add the filter/blur to the video so that twitter is prevented when the signal is sent to people's CRTs. Since it's obvious this DVD set for the cartoon series wasn't from a film transfer based on the obvious videotape artifacts, I'm wondering if it's possible that it could still be sharper than broadcast quality because it was from a videotape set that wasn't blurred yet. -
Eh, jagabo? For vertical resolution they should all be equivalent I thought.
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 21:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 15:18 -
3D Comb Filter and Pass Thru
By RidgeShark in forum DVD & Blu-ray RecordersReplies: 2Last Post: 14th Jun 2010, 22:36 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 05:46
