I bought an AW-VD920H to rectify this but Premiere insists on using Adobe Player as the Player Setting. AW-VD920H is not compatible with Adobe Player, so I need to change it to Windows Media Player. Any help would be greatly appreciated.
Thanks in advance,
Stephen
	Your miserable life is not worth the reversal of a Custer decision.
	i'm not sure what you are asking. premiere pro has nothing to do with adobe player. try again and describe your problem in more detail. --
	Adobe Player is the only video player to choose from under edit-->preferences-->player settings. I want to use windows media player instead. Your miserable life is not worth the reversal of a Custer decision.
  Premier Pro CS4 outputing in slow mo problem.By bsirrell in forum EditingReplies: 2Last Post: 16th Jan 2013, 11:08
  slow editing on cs4 premiereBy maplewood in forum EditingReplies: 22Last Post: 2nd Feb 2012, 13:41
  Need help on premiere pro CS4By george2005 in forum EditingReplies: 5Last Post: 27th Mar 2010, 05:42
  Video caputres fine in Premiere Pro CS4 but shows up blank on playbackBy mroutdoors in forum Video ConversionReplies: 7Last Post: 26th Dec 2009, 14:32
  Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
