I have a problem with my Hauppauge HD pvr2.
It dosent allow me to get to 720p. Or its really bad quality
Iv watched youtube videos to make it better, which I did what they did and its still really bad.
look at some of my videos on youtube to see my problem. My channel is ReactCodKiLLz.
Please help ME!!!
Results 1 to 11 of 11
What format is your capture source in?
I didn't look at your clips but...
If you want 720p as output you should capture from a 720p source. It seems to me that the HD PVR2 uses a very simple algorithm to downsize from 1080p. If your source is interlaced ie 1080i then don't expect the Hauppauge to convert it to progressive on the fly so 720p won't be an available option. Also, I don't have a composite dongle but I wouldn't expect it to provide an option to increase the resolution either.There's not much to do but then I can't do much anyway. -
Upconverting was not a feature on the hdpvr 1. The hdpvr 1 that I have only records the incoming resolution. It doesn't change it. And it won't accept a 1080p signal.Originally Posted by gll99
Basically it will record only what you throw at it. I'm assuming the same is true of the 2nd generation model.
Also the poster should check the connections to make sure nothing is loose. Also unplug and plug in the hdpvr again to make sure nothing is wacky with the connection to the computer.
Edit - I do believe the hdpvr 2 model will allow 1080p recording. Don't know for sure but I think it does.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Click on the "Format Settings" and choose the "Hauppauge H264 Encoder" tab. In the upper right hand corner of the panel there is a "Source" section which shows the input info
Edit:
I posted some info including pics of the panel later in this thread
https://forum.videohelp.com/threads/353688-Hauppauge-HD-PVR-2-issues?p=2230749There's not much to do but then I can't do much anyway. -
[QUOTE=gll99;2234177] Click on the "Format Settings" and choose the "Hauppauge H264 Encoder" tab. In the upper right hand corner of the panel there is a "Source" section which shows the input info
Edit:
https://forum.videohelp.com/threads/353688-Hauppauge-HD-PVR-2-issues?p=2230749[/QUOTE]
well I went to it and it is in grey which I cant click on anything. like I cant do anything to it..
how do I enable it?? -
You don't enable the source resolution within the HD PVR2 on that panel it's only providing information about the source and video input you selected in the previous panel.
So what does it show in the Source boxes for you? As you know you can down-convert by putting a check mark in the "Video Scaler" box and then choosing the scale-down option that you want but as I said before there are limitations if you do it that way. If your source box says 1080i then you can't select 720p since you can't go from interlaced to progressive. If your input is 1080p you can select 720p but the output will only be 30 fps even if the source is 60 fps.
It is much better to set the output resolution you want to capture at in the device you are capturing from ie... cable stb, xbox360.... . If you want 720p/60 fps then set the source (cable box, satellite, xbox360) to output that resolution and the PVR2 will automatically capture it for you as long as you leave the "Video Scaler" box blank.There's not much to do but then I can't do much anyway. -
Hey well I hopefully fixed my problem what I did was...
1) went to options on the top right corner.
2) then I went down to preference.
3) then go to other.
4) then there will be something called upload to YouTube.
5) click the bubble that has 1280 x 720 (HD)
That is what helped me but I haven't done a test video yet
but I hope u will remember those steps if any other person needs help like I did
Low output quality Hauppauge PVR 2.
By Jason4411 in forum Capturing and VCRReplies: 2Last Post: 17th Apr 2013, 16:58 -
Hauppauge PVR-150 capture quality, help!
By granturissimus in forum Capturing and VCRReplies: 17Last Post: 19th Jul 2012, 04:21 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
Mp4 format problem, the vid have a bad quality after i rendered it.
By aisple_aislesz in forum Newbie / General discussionsReplies: 12Last Post: 25th Apr 2011, 11:02 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
