hi all i recently a captured a live stream using tubediggger 4.4.1 and converted it to mp4 .But unfortunately when i play the video using VLC player or windows player the video plays at fast speed and no audio. could you guys tell me how to fix this problem so video plays at normal speed and have voice ?
I even tried to use ffmpeg to convert the flv video to mp4 instead of tubedigger convert it for me but i get this error:
track 1: could not find tag, codec not currently supported in container
Could not write header for output file #0 (incorrect codec parameters ?): Operation not permitted
Results 1 to 9 of 9
Insufficient information.
Post a mediainfo report of the file and, better still, a short sample of the video if you can.
Did you do a full convert in tubedigger or just a 'fix flv' ? -
Thanks for reply . it created for me mp4 so i assume it converted too! where to find mediainfor report ?
Don't use tubedigger's conversion routines.
Download the raw file and convert it with something else? -
The whole point of the 'fix flv' is to correct issues with live streams. It demuxes and then remuxes the flv in to a mp4 wrapper. No actual conversion ie change in codec etc. takes place.
We really need to see the original flv for a better idea but assume that did play ok.
Install mediainfo. Select text and copy/paste the report. -
thanks all for reply. That is what i exactly tried to do but Any video converter free version and ultimate version both failed to convert the full flv file(it stopped converting the video at 2 min for 16 min video).Is there any better converter that i should use to convert flv to mp4?
I tried the option of "convert without transcoding"in tubedigger the result was normal video playback but still without no voice. Initial problem was vlc couldn't play the video more then 30 seconds before it closes and it had no voice. Now vlc plays the video normally and i can move the vlc player slider to any part of video but unfortunately still no voice!
Here is mediainfo report:
General
Complete name : C:\test\Videos\TubeDigger\testvideo.flv
Format : Flash Video
File size : 10.6 MiB
Duration : 16mn 36s
Overall bit rate : 89.6 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : 7
Duration : 16mn 36s
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 10.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : Nellymoser
Codec ID : 6
Duration : 16mn 35s
Channel(s) : 1 channel
Sampling rate : 11.025 KHz
Bit depth : 16 bitsLast edited by spiderMan007; 20th Apr 2013 at 12:18.
what the H is nellynoser audio format
sounds like a major problem to me
MTS playing in slow motion but sound is normal speed
By nylongirl in forum Video ConversionReplies: 18Last Post: 10th Oct 2012, 00:04 -
mkv2vob: VOB converted video plays at ~5x speed
By shiroi in forum Video ConversionReplies: 1Last Post: 9th Sep 2012, 00:59 -
AVC1 to MP4 playback speed too fast
By Cathedralcat in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2010, 22:41 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 20th Sep 2008, 23:35 -
using a webcam, plus time-lapse software, to make a normal speed video..
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2008, 01:38
