i do a lot if table top instruction videos and the problem is i have to keep flipping the LCD screen on the camera from front facing the lens and back. Doing this in time breaks the fine connection to the LCD screen. I thought a way to solve this was to set up a remote 7 inch monitor on the table. Question is can i use one of the 7 inch monitors for a car backup camera or the monitors for the headrest used in cars? i can buy these for around $35.00 but i don't want to buy one and find out i can not plug my Sony handycam DCR SX40 into it or it will not work while making a video
Results 1 to 10 of 10
The specs for that camera says that you can record to a DVD recorder here: ("The DCR-SX40 supports a direct connection to the VRD-P1 DVD burner (sold separately), which allows you to burn DVDs directly from your camcorder without the need for a PC. ") But I have no idea if it can send a signal to a monitor while recording. I would try to hook it up to your TV while recording or monitoring and see if that would work better. If that works then buy a cheap LCD TV screen and set it on your desk. I have no idea if the car tv monitors would work. They are too small.
I've got 4 Sony camcorders and run 2 of them with an external monitor connected to the composite output while recording so I suspect yours will do it too. As long as the monitor you use has composite input I don't see why it wont work. Before getting the monitor, you could try connecting to the composite input on a TV to check that it works.
At $35 each, you're not losing much if it doesn't work, compared to pro monitors that can cost upwards of $1000US. IJS
Since you're shooting in SD, even an old TV set with composite or S-Video inputs will work. The big question is do you still have the adapter cable?
The camcorder has composite output. You can use that with any display that supports composite input.
thanks for the info i bought a sony DVD portable player and the specs did say AV output/input via a switch for the life of me i can not figure out how to switch from out to in
the DVD player has a cable with the res yellow white jacks at the end, the handycam also has a cable from the handy cam with the same jacks on the ends. I went to radio shack and got a switch box so i can plug both cables in the box. My issue now is how to switch the sony DVP FX750 to input player -
I second that.
Sony makes some oddball jacks and cables. If it doesn't just work, it may be a setting, or something as simple as closing the LCD panel to enable the composite output. Good luck!
EDIT: after closer examination, I haven't seen any portable DVD players (or laptops for that matter) that can be used as video monitors. It would be a nice feature, but it's just not there.Last edited by NTSC Refugee; 23rd Apr 2013 at 12:14. Reason: Add info.
I checked the manual and Sony's description for the DVP FX750 portable DVD player. You cannot use the A/V connections on your portable DVD player to accept input from a camera. The A/V ports can only provide output. They are provided to allow the DVP FX750 to be connected to a TV like a regular DVD player.
if you can find one i use a portable dvd player as a monitor, has a selector switch brand is digital labs model number dl730-pd. here is page of what it looks like http://www.kpsurplus.com/buy/digital_labs_dl730_pd_portable_dvd_cd_player/41958
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078
touchscreen remote...
By carlos28355 in forum Media Center PC / MediaCentersReplies: 4Last Post: 28th Jan 2012, 10:55 -
Remote Editor
By thedoingsful in forum EditingReplies: 6Last Post: 15th Feb 2011, 15:15 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
Which remote?
By Alomonger Pete in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jan 2009, 09:13 -
Remote
By WildParadise in forum Media Center PC / MediaCentersReplies: 14Last Post: 24th Apr 2008, 11:10
