Hi....
I have several VCDs that contain our family home video. As we know that VCDs resolution is 352x240 for PAL or 352x288 for NTSC. With Handbrake, I can rip VCD to MP4, but with only 352x288, if this MP4 is watched on TV it will too small to watch.
Ok.... then I try to resize that MP4 with Freemake Video Converter to 1280x720 so that we can watch that video on TV..... wow it's very very huge, it's about 1,8GB
The question is: how to minimize that file as far as possible??
Thanks for response....
Results 1 to 13 of 13
You are under a misapprehension.
Watching a 252*288 (PAL VCD size, not NTSC VCD size) video on your TV wont be displayed in a little box in the centre of the screen, it will be resized by your TV to fill the TV's native resolution.
Re-encoding from the VCD's mpeg1 to h264 will degrade the original quality, and re-sizing thru software to a higher resolution will degrade it further.
Your best bet would be to extract the original MPEG1 video from the VCD, and watch that, letting your TV handle the upscaling. -
What KBeee said.
Additionally, trying to upscale yourself in software from VCD resolutions will give you truly terrible quality output. You'd be best served to let your TV do the upscaling for you as TVs have some filters that can make VCD look OK even on HDTVs. I do want to point out that many if not most current BluRay players do not support VCD playback at all. I have a Philips DVD player that I use when I watch VCD. I also want to point out that stretching an upscaled 4:3 VCD image (note that ALL VCDs only support 4:3 video - there is no 16:9 - even letterboxed VCD is actually within a 4:3 window) to 16:9 is also a bad idea and even with your TV's filters it will look bad. For best quality watch your VCDs in 4:3 on your TV and just live with the black bars on the sides of the picture. -
Actually, jman98, though it isn't part of the spec, I've been able to create a Anamorphic 16:9 VCD for years (I use it as a demo in my collection). However, not many players support the flag (probably because they're hard-coded to assume 4:3 for VCD). "VCD_PLAY" software player from Roxio does.
Otherwise, I agree completely with what you said.
Scott -
VCD and mpg files can be problematic on some players. My Samsung DVR will play mpg files, but ONLY if I rename them from video.mpg to video.avi (no re-encode, purely a rename of the file extension). Won't play VCD's at all, only the demuxed mpeg renamed to avi...
Another option similar to this is to author a dvd with the original video. Most authoring programs should offer to reencode the audio from 44.1khz to 48khz and leave the video untouched since mpeg1 is allowable for dvd.Originally Posted by kbeee
Tmpgenc dvd author does this as do many other programs. Than you'll have a perfectly usable dvd to work with. And actually that might be better for file playback as a video_ts folder or use something like vob2mpg to get a simple single mpg file out of it (that is in dvd mode with the right dvd specs).
Please correct me if I'm wrong somewhere but that would be another relatively painless option to get a working solution out of this.
I was unaware that vcd wasn't part of the bluray package anymore. I don't have any vcds to worry about but I'm surprised that functionality has been removed. So hence a dvd would make more sense with minimal reencoding.
Again if I"m missing something in this option please let the original poster know. Thanks.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
First, TV media players vary widely in their support of MP4, MKV, as well as many other media filetypes. How do you know just WHAT yours supports? (since you don't actually name what your TV make & model is)...
I wouldn't recommend a tool until I knew exactly which format (and other specifications such as AR support, pulldown support, etc) this device is going to be capable of supporting.
Scott -
Cornucopia...
I don't know anything about AR support, pulldown, etc.... I can only give you link to the product. Here it is.... http://www.lg.com/my/tvs/lg-47LM4610
For sure, I have other movies (MKV and MP4) and play smoothly from USB Flash Disk connected to the TV from back panel. -
Well, you could use VCDgear to extract the movie from the VCD discs and feed that into MKVmerge GUI and see if your TV can play it, but as these TV media players always have limitations, the people who wrote the firmware may not have ever expected anyone to do that so it may not be supported.
Interested about the demo VCD disc, Scott. I had some VCD quality fan film files that I turned into an MPEG-1 DVD using Scenarist that I use sometimes as a test disc. I've found a lot of BluRay player that refuse to touch VCD at all or even standalone MPEG-1 video, but they all play my DVD correctly. -
Well, I've got a similar model LG - I'll try a few things on mine this evening (if I can get my son away from the screen).
<edit>@jman98, let me know by PM if you want a copy of a test VCD I did. I'd have to cut it down (it's ~60 minutes, and BORING - about "controlled burns").
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
x264 MKV to MP4: "WEB OPTIMIZED"? AAC? CRF?
By J81CHAT in forum Video ConversionReplies: 5Last Post: 27th Feb 2012, 17:52 -
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
How to convert HD MKV Vedio to Avi to play on my LG LED TV???????
By Sh@DY in forum Video ConversionReplies: 27Last Post: 2nd Oct 2010, 07:44 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30
