Hi,
I'd like to know haw to preview the resultls o SVCDs before burning and playing in DVD players.
A lot of times, mpeg-2 files encoded in TMPGENC look terrible in media player but very good in the dvd player. Actually, sometimes if I use different setting to encoded, the result can be worse in the Media Player and better in stand alone.
Pleas, help me!
I use VideoLan
Check the section (S)VCD/DVD Players on http://www.vcdhelp.com/vcdtools.htm
(The URL for VideoLan is http://www.vcdhelp.com/vcdtools.htm)
HTH"The future is no longer what it used to be" -
I create the SVCD image (I-Author or VCDImager).
Then mount the bin from the hard drive with Virtual Daemon (see tools).
Finally, I then play the (Virtual) svcd using winDVD.
This lets me test menus and the general look (sorry no subtitles).
However, the computer monitor is not the tv so there is no substitute
for the real thing.
Do you want to:
1) Catch a bad encode before you build an image? (a software dvd player may help to play the mpeg2)
2) Make sure you have authored correctly before you burn? (virtual daemon)
3) Not waste CD-Rs? (try cd-rw)
Hope this helps
Stand Alone DVD record Won't Play on PC?
By rkersh409 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2010, 12:23 -
stand alone dvd players that play .wmv or h.264
By scorpio291 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2009, 10:58 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 02:00 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 06:59 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 16:53
