Hi folks,
I'm looking to perform a fairly simple change within a Blu Ray structure to fix an issue with one of the video tracks. Having tried endless utilities without success I seem to have exhausted all options, so at this point I am hoping that someone here could point me in the right direction. Here is a detailed description of what I'm trying to achieve:
I have a Wedding video that is authored onto a Blu-Ray disc. It contains custom menu with multiple "Chapter" selections, each corresponding to its own video track (m2ts file). There are a total of 5 video tracks (Main Feature movie, Movie trailer, Photo Montage Movie, Save the Date Movie, and Wedding Toasts movie). There is a separate (6th) m2ts file which represents the Custom Menu. One of the video tracks was faulty (had audio sync issues). I have since gotten hold of a new "fixed" video track (in an m2ts file format), which I'd like to use to replace a faulty video track within original Blu Ray. I have ripped Blu Ray disc to a folder on my PC. Can someone kindly provide some guidance as to how to go about swapping the faulty video track with a "good" one while keeping everything else intact (Menu, File structure, etc.) I'd like to do it as cleanly as possible in order to retain original video quality and not have it re-encoded if possible.
Any help would be much appreciated.
Leshka
"CLEAN" does not equal "Simple". To do a replacement cleanly, you extract the assets, replace and then re-author.
Scott -
Cornucopia,
Thank you for stepping in to help! Can you kindly elaborate further on how to actually do the "extraction", "replacement", and "re-authoring" ? I'd really appreciate if you could provide a list of tools / apps I can use to perform each of these operations. Of course I'd be very thankful if you could also supplement a list of tools with an explanation on how to perform each of those steps (or at least point to a comprehensive guide). -
Baldrick,
BDFix suggestion sounds great. I went through the options and it does look solid and easy to use; however as you pointed out the Free version would not be of much use in my scenario. BDFix Pro is the version I need as it provides the option to replace / change video tracks, but oh darn, it comes at quite a bit of a cost ($400). A bit much for a tool, which I'm probably only going to use once or twice. -
Thank you.
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
Several blu-ray m2ts files to one single file?
By Mr Flibble in forum Blu-ray RippingReplies: 5Last Post: 14th Apr 2010, 10:34 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 10:14 -
Blu-Ray to single m2ts file without re-compressing
By Moondiver in forum Blu-ray RippingReplies: 8Last Post: 6th Jan 2010, 18:56 -
help: when a blu ray movies is split into more than one m2ts file
By lodwales in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 09:51
