Hello,
I want to edit video files encoded with x264. I did some research on this topic. People say that x264 cannot edit. Firsty, it should be converted to intermediate format.
I want to the best quality. How can i do this ?.
which video format can i convert to reach the best quality editing? and then, which codec can i use to encode well ?
original file >>> intermediate file
intermediate file >>> end file
which format should be intermediate file? ( please give me details about it, codec etc )
which end file format should be ? ( please give me details about it, codec etc )
File size is not important to me.
I attached my original file.
Best Regards
What kind of editing ? You can just cut with avidemux or join with andys flv joiner.
And please wait some DAYS before you bump. -
About the intermediate file, basically every lossless video codec should work. UT Lossless video codec, lagarith, Huffyuv, MSU Lossless Video codec even x264 in lossless mode are all viable options.
What do you want to do with the file, normally the usage-scenario restricts the target format&co,...which end file format should be ?
If you habe to use 'videocharge studio', doesn't it support H.264 content?
Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?
By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 12:45 -
x264 log file
By txporter in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 16:40 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
Bitrate of avi file and x264 file
By maass in forum Newbie / General discussionsReplies: 8Last Post: 9th Apr 2009, 08:27 -
convert x264 HDxT file to ps3 playable file
By yodaddi in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Mar 2009, 22:02
