OK, so I setup my windows on my new SSD drive and I've had no problems...until now...
OK, so everything was working fine. Then my 2 TB HDD decided to not show up. I replaced the SATA cable and made sure everything was tight, after all else failed, and it showed up. However, in the BIOS it is now listed as an IDE drive and not hidden away (When I changed everything to AHCI mode). Then the same thing happened to my 1TB drive just now. This time I simply switched SATA connectors on the MOBO.
Anything to be worried about? Is there something I did wrong?
Smile
Smile -
Did the drive appear correctly when cable was connected to different SATA mobo connector? I recently had similar problems with PCI SATA adapter, and drive was recognized correctly when cable was switched to another SATA port on the adapter card.
When I did my initial re-install of Win 7 on my SSD, I had set all the BIOS functions to ahci.
When everything was up and running, after the BIOS screen flashes, none of the drives show up.
A second screen appears and disappears very quickly with AHCI at the top and all the drives (Fast, so it took a couple of restarts for me to see them all)
In BIOS none of the drives are listed in the SATA section (Can't remember the name) but when I got to Advanced, I can select from all the drives as the startup drive.
All drives would show up in Win 7.
After unplugging and plugging back in the drives, the would all eventually move back to being seen after the BIOS screen flash as well as in BIOS (With the exception of the SSD drive).
So, now 3 of my drives (SATA drives) are IDE and no longer AHCI...but I don't know if this matters. They are working.Smile
Smile
Is use of AHCI now the default for Win-7 ?
By Seeker47 in forum ComputerReplies: 1Last Post: 4th Jan 2013, 21:23 -
AHCI mode Worth Installing to Replace IDE mode?
By wulf109 in forum ComputerReplies: 13Last Post: 24th Aug 2012, 12:42 -
Things have changed
By Marco33 in forum Off topicReplies: 13Last Post: 23rd Dec 2010, 21:29 -
AHCI benifits
By rizvii in forum ComputerReplies: 2Last Post: 6th May 2009, 07:06 -
WMP changed
By KLouis22 in forum Software PlayingReplies: 5Last Post: 5th Dec 2008, 07:36
